Here’s the problem—rear door opening catches muck from rear tire
mv213
J.P.
2025 4Runner Offroad Premium
The rear door opening/lower rear corner of the door is a terrible design. It catches tons of splash from the rear tires. I believe in a few years we’ll be seeing rust spots develop there. They should have at least extended the fender flare down further.
I made up a mini mudflap to hopefully prevent this. After removing two 10mm bolts in the fender liner, it slips inside the liner. The bolts are then replaced.
I’ll be doing something along the same lines at the rear edge of the front wheel opening to fill the gap between the fender flare and mudflap.
I would be interested in a better solution if anybody has one!
2025 2026 4runner 6th gen Here’s the problem—rear door opening catches muck from rear tire PXL_20260108_185227642_Original
2025 2026 4runner 6th gen Here’s the problem—rear door opening catches muck from rear tire PXL_20260529_215140712.NIGHT_Original
2025 2026 4runner 6th gen Here’s the problem—rear door opening catches muck from rear tire PXL_20260530_172740778_Original
Are you worried about moisture and debris getting tightly stuck there between the metal you’re talking about and the flap?
BonRunner
2026 TRD Sport Premium / WCP
Can u share the dimension on a PDF so that we can print & trace it? I'd greatly appreciate it & share the same frustrated issue with you on a white car. 🙏🙏
mv213
mv213
J.P.
Mainly just the lower corner of the door, which is unprotected. The actual piece of the body that meets the door is a plastic piece.
mv213
mv213
J.P.
Give me a couple of days. I'll see what I can do.
mv213
mv213
J.P.
Well, it appears my scanner has taken a dump so I can't produce a life-size pattern for you. You should be able to use this pic to make your own pattern from some thin cardboard (like from a cereal box). Take the two bolts out and experiment till you're happy. You may come up with something better! Good Luck.
2025 2026 4runner 6th gen Here’s the problem—rear door opening catches muck from rear tire PXL_20260530_223731672_Original
BonRunner
This is perfect. Thank you! 👊
