Fuel door won't open
Alaska Guy
Rich
Alaska
2025 4runner
I have 2025 4runner ORP (Gas) is there an emergency procedure to open the fuel door if it won't open pushing the dash button?
All I can find in the manual is “see your dealer”. Not much of an option if you way out in Timbuktu.
My fuel door will open this is a preemptive question.
remove the access panel on driver side interior and operate it manually
this is an image from a borescope on my 2025 4runner,
taken thru the bottle jack access door
motor that activates the gas door is white assembly and you see a
little black plastic pull handle circled in green and closest to camera.
2025 2026 4runner 6th gen Fuel door won't open 1779638018925-24
get a hold of that handle and pull it releases door latch.
may need to pull trim so you can get your hand in there
or fashion some type of hook from a coathanger
KD4R6G_25
Kevin
Missouri
Tundra TRD Pro & 4Runner TRD Off Road Premium
KD4R6G_25
Kevin
Missouri
We have. 2025 Hybrid ORP…the jack compartment didn’t have a visible handle when the jack was removed…but the 12 Volt accessory battery is visible as you look down. Is the manual release handle in a different location in the Hybrids?
Kev
you see that part where I say 'may need to pull trim' ?
yank this trim and reach in and find the handle. don't cut yourself
2025 2026 4runner 6th gen Fuel door won't open 1779728495358-av
myself...if it ever happens to me ...
I'm using my borescope to send in a fish loop
and pulling from bottle jack access door
NOTE: The TIS procedure for replacing the fuel door motor
shows that you to go in via the Jack Access door
2025 2026 4runner 6th gen Fuel door won't open 1779887965198-th
KD4R6G_25
Kevin
Missouri
Gotcha…that makes sense now….
