DangItsDen
DangItsDen
Hayden
Looks really good. What "kit" did you install? I see they sell a several packages. Did you install the front 1.25" and rear spring spacer kit?
Idk how I missed this message but it’s just the 1.25” front spacer kit. No rear lift.
FourWalker
MA
2025 4Runner TRD Off-Road
Peak 1.25 front and Dobinsons 15mm coil spacer in rear.
2025 2026 4runner 6th gen Peak Suspension 1.25" Leveling Kit + TRD Pro Wheels (on TRD ORP)... Post your Peak Suspensions IMG_4361
2025 2026 4runner 6th gen Peak Suspension 1.25" Leveling Kit + TRD Pro Wheels (on TRD ORP)... Post your Peak Suspensions IMG_4363
DangItsDen
DangItsDen
Hayden
That looks dialed! Do you have a link to the spacers? I can only find the ones that fit the 5th gen, but it may be the same
FourWalker
MA
DangItsDen
DangItsDen
Hayden
Updated rig shots with the method 703s and Toyo AT3 285/70r17
2025 2026 4runner 6th gen Peak Suspension 1.25" Leveling Kit + TRD Pro Wheels (on TRD ORP)... Post your Peak Suspensions IMG_1852
2025 2026 4runner 6th gen Peak Suspension 1.25" Leveling Kit + TRD Pro Wheels (on TRD ORP)... Post your Peak Suspensions IMG_1850
DangItsDen
DangItsDen
Hayden
FourWalker
MA
mfoga
r4unner
Sounds like those rear spacers are made to adjust for lean right to left after lift is installed. Just curious why would you do a leveling kit in front and them raise the rear half of what you just added to the front to level it. Am I missing something here?
DangItsDen
DangItsDen
Hayden
Those spacers can be used for lean on one side or on both for a small height adjustment. I had some on my 5th gen too.
I would do this in addition to the front lift to keep rake. I didn’t use the leveling kit to make it level but to just give the front tires a bit more room. After it all settled in I think I would like a bit more rake so it doesn’t squat with cargo and people in the back.
FourWalker
MA
This exactly.
