FourWalker
MA
2025 4Runner TRD Off-Road
Still waiting for it to come in, but will report back once installed. Happy that it just slides right over the factory bolts at the top of the struts (still enough thread to get the nut back on after install). Rake on my 4R is only about 1.75 in, so this should be good. Eventually may lift the rear with the .75 ICON springs if we end up doing a lot of towing or camping with it so that it doesn’t ride nose high when loaded.
how are you liking the peak spacer? Was it a true 1.25” lift?
FourWalker
MA
Were you able to get the spare tire up there? Just got these tires based on this post but shop said they can’t get it up there.
Hey guys. This is my first post. Thought I’d show the stance of my Sport Premium after installing a 1” ReadyLift leveling kit, and 18" TRD Pro wheels (+20 offset) wrapped in 275/70/R18 Nitto Terra Grappler G3 treads (SL load range). This is my wife’s daily driver so comfort was a major factor in choice of tires.
I’m running 37 psi and she feels the ride is smoother than with the factory 20” rims. ?
Stock wheels:
More photos:
FourWalker
MA
OP thanks for all the work on this post. I went with a similar setup. Same wheels and tires. 1.25 Peak lift going in next week and a .5 rear lift to maintain a little rake.
2025 2026 4runner 6th gen TRD Sport on 1" Lift + 18" TRD Pro Wheels + 275/70/R18 Nitto Terra Grappler G3 Tires IMG_4170
2025 2026 4runner 6th gen TRD Sport on 1" Lift + 18" TRD Pro Wheels + 275/70/R18 Nitto Terra Grappler G3 Tires IMG_4169
2025 2026 4runner 6th gen TRD Sport on 1" Lift + 18" TRD Pro Wheels + 275/70/R18 Nitto Terra Grappler G3 Tires IMG_4171
2025 2026 4runner 6th gen TRD Sport on 1" Lift + 18" TRD Pro Wheels + 275/70/R18 Nitto Terra Grappler G3 Tires IMG_4176
FourWalker
MA
Peak spacer is great. Install wasn’t too bad. Fits perfectly over factory studs with just enough thread to torque the nuts down. Rides great, no problems whatsoever. A couple before and after pics.
2025 2026 4runner 6th gen TRD Sport on 1" Lift + 18" TRD Pro Wheels + 275/70/R18 Nitto Terra Grappler G3 Tires IMG_1581
2025 2026 4runner 6th gen TRD Sport on 1" Lift + 18" TRD Pro Wheels + 275/70/R18 Nitto Terra Grappler G3 Tires IMG_4438
JLR
Seattle
2026 TRD Offroad
I just had the 18” TRD black wheels with the +45 offset, and 275/70R18 Pirelli XTM tires installed. The tire was a really tight fit in the spare location. It does fit ( barely) but hangs down a bit more than I like. I am planning on doing a bit more poking around down there to see if I can get a better fit.
JLR
Seattle
2026 TRD Offroad
Pic
2025 2026 4runner 6th gen TRD Sport on 1" Lift + 18" TRD Pro Wheels + 275/70/R18 Nitto Terra Grappler G3 Tires IMG_2926
