What is the best Sky Box for the ARB 3/4 System
chris718
chris
PA
2025 4Runner TRD Pro
Looking for a skybox that can hold snowboards / luggage and fits on the ARB 3/4 roof base system (factory option) that will not interfere with the tailgate when it’s up. Does anyone have a currently Thule / Yakima model that is being used on this that works and fits appropriately?
chris718
chris718
chris
PA
Pinging to move this up. Any thoughts?
Percy_4Run
Kenton
Everest 2025 TRD Offroad 4runner
I’ve been looking into a roof top storage as well, which dimensionally it looks like there should be some that will fit more so of the Thule brand. The only thing is having to either use “T-nuts” or use a set of bars to attach to the rack and then the box. Also if I’m understanding it correctly with the factory 3/4 rack depending on Trim the dynamic max weight is 135lbs.
also Thule has some good measurements for all their different boxes right here.
https://www.thule.com/-/s/approved/std.lang.all/90/75/649075.pdf?rev=5.1
also the attachable bars i was talking about.
https://www.thule.com/en-us/roof-ra...essories/thule-caprock-cargo-box-kit-_-611330
Again, the weight part is the concerning thing I personally haven’t figured fully out and have not gotten anything yet from this research but will update if/when I do
chris718
chris718
chris
PA
Agreed. I believe the Force 3L is a decent option for size and weight. I’m having one fitted Thursday and will let you know if it works on the ARB setup.
chris718
chris718
chris
PA
Well, fitted a force 3L and I think it’s a great option. Fits like a glove you just need to take out one cross bar on the ARB rack.
2025 2026 4runner 6th gen What is the best Sky Box for the ARB 3/4 System IMG_2684
2025 2026 4runner 6th gen What is the best Sky Box for the ARB 3/4 System IMG_2685
Percy_4Run
Kenton
Which cross bar did you have to take out? And hardware did you use for for mounting it to the rack if you don’t mind me asking? It looks great by the way!
chris718
chris718
chris
PA
Believe took the second bar out from the front. I can check but my memory is shit.
Standard hardware with the box. Drove it from PA to Vermont doing 80mph. No wobble or shake or issue. Solid. Takes 5 minutes to mount.
Percy_4Run
Kenton
That would be appreciated, thanks!
Awesome to hear how solid it is, and the standard mounting hardware is those little finger type things that are usually used for the cross bars just clarify?
2025 2026 4runner 6th gen What is the best Sky Box for the ARB 3/4 System IMG_5806
chris718
chris718
chris
PA
Yes, the typical finger-like devices. They will wrap and lock down with pressure. They don’t close fully but you don’t need it fully closed so long as it’s locked around and the other mounts are locked. Even with just two locked down you can’t move the box. I wouldn’t be worried about it failing.
chris718
chris718
chris
PA
Attached view. 2nd rail removed.
2025 2026 4runner 6th gen What is the best Sky Box for the ARB 3/4 System IMG_2702
2025 2026 4runner 6th gen What is the best Sky Box for the ARB 3/4 System IMG_2703
Percy_4Run
Kenton
Ohh I see how it attaches now. I’ve never used/actually seen in person how these boxes clamp down. Well sweet I know what I’m doing now for our 4Runner rack. Thanks again!
