Adding features from other Trim Packages?
Motosprout
Adam Danyeur
Flathead Lake Montana
Recently purchased a TRD Sport Premium in Supersonic Red. I did not get the rearview mirror with the camera option. Can I simply order a mirror from Toyota to plug and play?
I'm guessing most 4 Runners come with the same wire harnesses. What other plug and play features can I add?
I don't actually know for sure whether you could just plug in the toyota mirror with camera and have it work, but I do know exactly what connectors you should look for - since I recently replaced my OEM mirror (with rear view camera integrated) with the Wolfbox G900TriPro - which means I have an OEM unit to sell. I assume you have the rear camera that shows on the big display when in reverse. I'm not sure if the camera for the rear view mirror is the same one but ... probably?
So, assuming you have a toyota-integrated rear view camera, the photos below show the connectors to the OEM mirror. If you have those and want to buy my OEM mirror, lets talk. (BTW, the housing in front of the mirror slides down the windshield and the center piece pulls toward you.)
Closeup of the two connectors:
2025 2026 4runner 6th gen Adding features from other Trim Packages? 20251221_144803
Connectors on the mirror disconnected
2025 2026 4runner 6th gen Adding features from other Trim Packages? 20251221_145116
Mirror removed
2025 2026 4runner 6th gen Adding features from other Trim Packages? 20260116_065012
Mad Ghost
Wylie Texas
4Runner ORP and Avalon
They actually use a separate camera for backup and rearview mirror. I’m trying to find a kit that will relocate the rear view camera up high near the wiper
2025 2026 4runner 6th gen Adding features from other Trim Packages? IMG_3719
Dead Horse
Oklahoma
That camera/mirror is only included with the tow-tech package as far as I'm aware, so I doubt it'll be that simple. It's an extra camera, wiring, and mirror. Probably five other things too lol. If you really want that feature, I know there are quite a few aftermarket setups that would probably legitimately be easier to install and work better (no customization on the baked-in setup).
Same with the dual climate. Probably not really possible, if past models are any indicator...None of the vents/actuators/blend doors/etc down in the dash were the same as the non dual.
Motosprout
Motosprout
Adam Danyeur
Mirror removed
Thank you for showing the plugs. I will have to take off the mirror and compare.
dual climate adds the blend doors, everything else is the same across the trims
xp0nex
2025 4Runner ORP
I've been curious about the HUD from the Platinum trim.
i would think that would be a nightmare, as you would have to replace the whole dash piece to get the hole to insert the hud projector. if i remember correctly the dash top is a whole one piece ?
unless you jerry rig it and just cut a hole and insert the projector :)
also not sure, if they have a different front windshield for the hud dispaly. i dont see a overlay film in the area for my hud dispaly, its just straight windshield.
Dead Horse
Oklahoma
Dash cover doesn't look that bad at first blush. Looks easier than my grills are going to be LOL
