Alberta Lithium Battery Company
Van Solo
Van
Calgary / Canada
***Updated to correct battery size.
I was looking for an alternative to the 12Volt Lead Acid battery group 48 H6/LN3 when I came across this Alberta Strong Company.
I had a great conversation with them that lead me to choose this company for my new battery to power our 4Runner.
The technology this company has put into these batteries is a game changer in my opinion.
Bluetooth that keeps you informed of your battery life and realtime values.
https://www.ablithium.ca/?_gl=1*1nh...BwE&gbraid=0AAAAAD4YHFb2oOGgjt02PN-0LDn2EgTjI
2025 4runner 6th gen Alberta Lithium Battery Company logosss
Van Solo
Van Solo
Van
Calgary / Canada
Not the same product my friends, nor is this a Canadian company
My friends and I build power stations for overlanding as well.
https://ca.litime.com/products/12v-100ah-group-24-lithium-self-heating-battery
Here is the same product half the price
Be aware Li Time is not a replacement battery like the Alberta Lithium Battery.
Completely different application here.
LiTime Specs:
12.8V
100Ah
Not The same product my friends, Alberta Lithium Battery is a drop in Starter Battery unlike LiTime and Not Canadian. LiTime Website says DO NOT USE AS STARTER BATTERY
It's definitely good to have options and be able to make choices that are right for you.
The reasons I choose Alberta Lithium Battery Company is based on a few factors.
1. The telephone conversation I had with Paola. It was rather refreshing and very technical
2. Alberta based Canadian Company
3. Options and Technology
This Battery is a full replacement to drop in place of your 12Volt Lead Acid OEM battery.
Alberta Lithium Battery offers a drop in Lithium option that is 100% compatible and offers increased Ah and higher CCA (see below)
*****Updated Specs 4R Hybrid battery
13.2V
60Ah
850CCA
Starter/Deep Cycle Marine IP67 Mercury Spec LiFePO4 + Na-ion Bluetooth Heated Battery
After our conversation with the team at Alberta Lithium and the FJ Cruiser they operate with a
lithium starter battery for the past few years no issue's with regards to the Alberta Winters!
Im so excited to get this battery installed and reap the many benefits including weight reduction!
Stay tuned installation scheduled for this coming week.
Thank you Alberta Lithium Battery Company for the advanced technology.
Haruharu
Garth
Winnipeg
4Runner TRD ORP
That is really cool. I didnt know' people swap a SLA for Lithium in cold weather. Usually, automotive industry relies on lead acid because it can charge in cold temps, which lithium has trouble with. I was under the impression you were looking to build a power source for your overland setup, if this is for your starter I am impressed.
In the past, self heated batteries take an hour or two before they start charging. Have fun and share pics of this battery in your bay!
Haruharu
Garth
Winnipeg
4Runner TRD ORP
So which size are you going to go with? If I plan on building power station in the back already, will I still benefit from upgrading the starter battery?
and will it work with the alternator?
Van Solo
Van Solo
Van
Calgary / Canada
like I said, not the same at all.
correct in the past!
Alberta tested in toyota fleet for the past 3 years all year round without issue.
Will do!
https://www.ablithium.ca/product/ne...spec-lifepo4-na-ion-bluetooth-heated-battery/
mars001
2003 4Runner SR5 4.7 V8
I thought lithium battery needs a different charger? If it's a drop-in replacement, how is it charged?
Never mind. Saw that it comes with an onboard BMS for charging.
Van Solo
Van Solo
Van
Calgary / Canada
Yes we will benefit.....
The starter battery will be the 60Ah / 850CCA this will replace the starter battery and free up weight! Then increase power and reserves.
Then we will ........
2025 4runner 6th gen Alberta Lithium Battery Company Screenshot 2026-01-18 at 20.15.57
work on further options with Alberta Lithium Battery Company when we decide what direction to go with for a power source. They have so much experience and are great to worth with.
Vincenzo
Southeast
Ionic has had a battery with bluetooth and app technology for quite a while. Have been running them in my boat for over 6 years.
quadna71
Delaware
2025 4runner
They state that the battery is also "+sodium-ion". But aside from stating in the description that it includes a sodium ion battery to absorb voltage spikes they never explain how it is integrated. Even the specs printed on the side of the battery (which is made in China...so not as Canadian as we would hope) don't mention the NA-ion integration. Some clarification from them on that would be great.
Van Solo
Van Solo
Van
Calgary / Canada
“Like Apple”
Van Solo
Van Solo
Van
Calgary / Canada
Picked up ! Images are before Installation!
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2746
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2745
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2744
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2751
Van Solo
Van Solo
Van
Calgary / Canada
Installation Completed, thanks to Southpointe Toyota in Calgary, Alberta Canada!
These are live images of the battery operating!
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2753
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2755
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2754
Van Solo
Van Solo
Van
Calgary / Canada
Update:
Upgraded today to the Group 24 Sized Alberta Lithium Battery featuring:
100Ah / 1000CCA Deep Cycle / Starter Battery
We had to modify the Top battery mounting bracket of the 4runner. (Images Soon)
(OEM Battery Bracket)
We removed the two battery hold down points from the back and front side of the bracket by drilling out the Spot Welds. We then filed the edges smooth and then proceeded to cut out a piece that runs near the Positive Battery Post as the battery is taller than the original H6 / LN3 and filed the cut edges smooth and started the painting process.
The OEM bracket has 4 points that attach to the vehicle.
1. Rear of the Battery (No Grommet or Spacer needed)
2. Front of the battery (1/2 inch robber spacer / grommet installed with isolator in the centre)
3. Left of the Battery (1/2 inch robber spacer / grommet installed with isolator in the centre)
4. Right of the battery (1/2 inch robber spacer / grommet installed with isolator in the centre)
Images to be loaded shortly.....
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2823
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2824
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2825
2025 4runner 6th gen Alberta Lithium Battery Company IMG_2826
