**Solved** Stock rear suspension has popping sound when loaded up with weight
quadna71
Delaware
2025 4runner
Our newish 4R has a sound coming from the rear suspension. It only happens when there is a decent amount of weight inside, but I don't think it is overloaded in any way. For example, last night we had 4 people inside and it happened all the way to/from a restaurant. My in-laws are both slim and probably <150 each, my wife is about the same, and I'm more like 250. But there was nothing else in the vehicle...and each time you hit even the slightest bump there was a popping sound from the rear suspension. The ladies in the back seat both agreed that it is coming from the right rear side but that's all I can determine.
On our trip back home today it was my wife and I and a bunch of camping supplies in the back. The heaviest item was a battery-powered cooler loaded with food but it was still enough that we heard it occasionally when crossing some small frost heaves on the road.
We have heard it before and I tried to locate it once. I had loaded the back up with bottled water and canopy weights and it was enough to reproduce the sound when driving, but I couldn't find anything wrong when laying underneath and tugging on everything.
Any ideas? Anyone heard of others having the same issue? I know I can call the dealer and let them figure it out as it only has 3400 miles on the odometer, but I'd like to have some due diligence accomplished before going to the trouble of setting up an appointment.
Thanks!
TyRoosevelt
Tyler
There are a lot of people who are having issues in the rear. It is not necessarily the suspension. What I would do is get a mechanic’s stethoscope and have someone push the vehicle up and down from behind and see where the sound is coming from.
Also move the tires back and forth rapidly and see if you have any brake noise. I would tell you to take it to the dealer but they are generally worthless if you can’t pinpoint the noise somewhat. I had a similar noise in the rear and it turned out to be the calipers. Told the dealer it was the calipers and they said it was the transmission making normal sounds. It was the calipers.
Cranberry
Manitoba Canada
Unfortunately i agree with TyRoosevelt.
the one thing Toyota is terrible at is diagnosing sounds.
your best bet is to have somone else drive the vehicle while you sit in the back and try to search out or pinpoint where the sound is coming from.
go to a gravel road or gravel pit or some place where its safe and you can just do laps at a safe speed while you investigate in the back.
i had a similar issue on my Gen 5 that i swore was the rear hatch area, but after trying the method i just noted now, i pinpointed the sound to the moonroof rails.
best of luck!
DannyvanDelft
Danny
Strongsville
2026 4Runner TRD ORP
Thanks!
Do you have bigger than stock tires? If so, the added weight is making them rub. The popping noise is the tread popping against what it's rubbing on.
take off the ark guards, can you recreate the issue ?
if yes
take off whatever you added to the roof (solar panels), still have an issue ?
quadna71
quadna71
Delaware
2025 4runner
No, stock tires & wheels.
quadna71
quadna71
Delaware
2025 4runner
if yes
I did pull off the ARK panels as I determined the one on the left was making a creaking sound where it contacted the frame. As I only had the rears installed it was a quick removal. I intend to put them back on once I clearance that one spot a little with an oscillating multitool a little. I did pull off the solar panel too and it didn't eliminate the sound so I put it back on. Aside from floor mats, everything else is pretty much stock. So I'm back to square one. Looking into putting a GoPro underneath to see if that helps me see something.
quadna71
quadna71
Delaware
2025 4runner
Hmm...I did not check that. It's in the left compartment in back, right? I'll check that tomorrow. But the devil's advocate in me wonders how that could cause the clunk if it only happens when the suspension is taxed with weight.
quadna71
quadna71
Delaware
2025 4runner
Update: no real updates. I did confirm the jack is tight, I lowered/raised the spare in case it wasn't fully seated, and I still haven't put the ARK panels back on. Like I mentioned earlier I did remove the solar panel and the sound was still there so I reinstalled it. It's been a little chilly here so I haven't done much troubleshooting aside from hearing it pop occasionally when I hit light bumps. I'm still hoping to dig deeper once it warms up a little. I must be getting old because it no longer fun laying on the ground outside when it's in the teens.
Cranberry
Manitoba Canada
Have you tried letting the truck get warm in a garage yet to see if the sound goes away once warmed up?
quadna71
quadna71
Delaware
2025 4runner
I don't have that ability right now (garage is full of stuff for our bathroom remodel but also not heated) but it was good thought!
quadna71
quadna71
Delaware
2025 4runner
if yes
Well, you nailed it - the ARK guards were to blame.
I originally removed them because it was creaking, clearanced them enough to stop the creaking, and then eventually put them back on. Last week we were loaded up for a long weekend at the in-laws and it was popping all the way to Costco and then on to work in the morning. It was making me so frustrated that I was starting to not enjoy driving it anymore. During my lunch break I visited the parking lot with a socket, ratchet, and needle nose to start removing them again. This time I could see where they were making direct contact on the "top" of the frame and not just rubbing against the sides of the frame. Turns out there is enough squish in the rubber body mounts to compress and allow them to make contact. Each time the vehicle would hit even the slightest bump it would make the guard slip left/right where it contacted the top of the frame. End of the day we hopped in the 4Runner (we work at the same place) and headed north....the ride was silent the rest of the weekend. Even loaded up with 4 adults and a cooler it was quiet. Sheesh....I even removed them once and then put them back on and didn't realize they were causing it all along. I'm sort of pissed that these guards aren't dialed in a little better but in the end I was causing the sound by installing them.
Now I don't know if I want to continue trying to modify them so that they fit better or just chalk it all up to a learning experience. Sort of a pain in the @ss to deal with installing them, marking them, removing them, trimming, and then repeat over and over. And it's not like there is any adjustment to mounting them either - they have a hole and it fits over the threaded studs in the wheel wells. Definitely can't return as they are months and months old as well as have been installed. But overall I'm pretty disappointed in the product. Ordered them, took longer than promised to arrive, was missing a majority of the hardware, took weeks (3 plus) to reach someone to get the rest of the hardware shipped, and now all the frustration due to them not fitting the 4Runner very well.
I guess you win some and you lose some. And now I'm happy driving my 4Runner once again.
