vready
Vince
Hood River, OR
I was asked over on this thread to explain how I wired up the lighting on my Sherpa Capitol rack.
My lighting setup includes a RIGID SR-Series 40" Midnight Optics light bar, four Baja Designs LED Dome scene lights, and power for my rooftop tent (with the option to wire for a solar panel in the future).
Here's a hero shot of how it looks in action:
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup 2025 Toyota 4Runner(C4 Lo Pro)
Knowing that I wanted the option for three capable circuits on the roof, we used an insulated cable with 4 strands of 10 AWG copper for the main run from the engine bay to the roof, which enabled us to use the black wire as a common ground, and the other three strands as positive leads.
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4892
The cable runs from the engine bay up the driver's side of the windshield (directly adjacent to the rain gutter) and fits nicely under the bottom lip of the fairing.
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4869-Edit
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4880
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4881
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4883
The cable is secured using the KC Wire Hider which is fastened to the glass using 3M VBH double-sided adhesive tape. To ensure good adhesion, we thoroughly cleaned the glass and did a final wipe with isopropyl alcohol before attaching the KC Hider strip. As you can see, this 4X10AWG insulated wire is pretty thick, so the KC Hider doesn't clip closed the way it was intended, but it still has a solid hold on the wire and works great. The aesthetics are nice, too.
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4884
There is a little step where the KC Hider has to go from the surface of the windshield glass to the weatherstipping on the roof, and as you can see in this photo, we stacked little stips of 3M VBH tape to maintain continuous contact between the hider and the mounting surface. That was really the only tricky spot.
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4870
Once the 4X10 AWG cable hits the roof, it's terminated in a bulkhead connector from Deutsch, which is mounted on a custom, 3D printed bracket designed by Phil Gragg at Offroad Toy Outfitters in Vancouver, WA. Note the OTO logo on the top. After printing a few prototypes to refine the design, the final piece was printed on a Bamboo using PETG CF carbon fiber filament, and the thing is bomber!
This photo gives you a nice look at how meticulous Phil is with the adhesive-lined heat shrink tubing.
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4872
From the bulkhead connector, the wiring breaks out into three 2-wire 16 AWG runs that terminate in a location which is convenient to access from the sunroof (in case I need to change something while the rooftop tent is installed...). Here again, we're using Deutsch DT-2 type connectors, and they are weather sealed and very secure.
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4888
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4873
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4874
From there, everything just runs cleanly around the perimeter of the Sherpa rack secured to the 1X2" crossbars using Sherpa T-slot cable clips.
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4875
The Baja Designs scene lights are sequentially wired from the furthest one back to the DT-2 connector, and the cabling is spaced to match up with the handle openings on the Capitol roof rack.
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4894-Edit
The finished install and cable routing looks like this.
If you need one of these, Phil at OTO took detailed measurements and can make a custom wiring harness and ship it to you.
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4865-Enhanced-NR
Can't say enough good things about working with him.
You can reach him at (360) 440-6375 or [email protected]
scorp
None
thanks for the photos and write up, much appreciated!
Mad Ghost
Justin
Wylie Texas
4Runner ORP and Avalon
Looks real good thanks for sharing. What is the under the hood setup like and switches?
vready
vready
Vince
Hood River, OR
That is still a work-in-progress, and I'm researching options. I might use something like the SDHQ Hybrid Under Hood Power Solution to run power up to the engine bay once they come out with a kit for the 6th Gen 4Runner.
As far as accessory switching, I'm planning to use relays and wire everything into OEM switches on the dash. I considered things like SwitchPro, but just prefer the clean, OEM feel.
I purchased these switches from CaliRaised, and dropped them in, and will be wiring to them:
2025 2026 4runner 6th gen Wiring Lights on a Sherpa Capitol Rack - DIY install how-to writeup _W0A4898
The Baja Designs scene lights are mainly for around camp, and are low amperage, so they won't be tied to the ignition switch, and are also independently switchable (using a button on each unit).
My 4Runner didn't have the 4 Pre-wired AUX switches, or it would have been much simpler.
I'll give an update once that's done.
Slacker
Evan
San Diego
2025 TRD Off-Road Premium
Great writeup! Looks fantastic as well.
Undefeatable
Kevin
Southern California
This is one of the best write-ups I have ever seen.
Made me someone who was casually interested in a roof rack + lighting to someone who's planning on seeing how much of this stuff will go on sale for Black Friday :LOL:
SteveB78
Steve
2026 4Runner
Sadly it seems they don't make this for resale, I contacted them and they sent me over to Blaze Offroad, unfortunately they don't make the roof rack harness anymore like they used to. I think I'll wire this up myself, how hard could it be?
