Tire size calculator & wheel tire poke / visualizer websites
Not sure if anyone uses this website but it has multiple tools to determine a lot of different visualizations of OEM vs. a new tire size
https://tiresize.com
Tire Size Tools:
Tire Size Converter
Speed Calibration
Gear Ratio Calculator
Wheel Offset Calculator
Tire Conversion Chart
Bolt Pattern Finder
Tire Pressure Calculator
Tire Height Calculator
Metric Tire Conversion
Tire Size Calculator
Tire Height Chart
All Tire Sizes
Wheels
https://www.willtheyfit.com/
this website will give you a visualizer of different offsets (poke) of wheels and tires roughly
also wanted to add wheel size specs website
https://www.wheel-size.com/
just to give you an idea
2025 2026 4runner 6th gen Tire size calculator & wheel tire poke / visualizer websites tiresize dot com 1
2025 2026 4runner 6th gen Tire size calculator & wheel tire poke / visualizer websites tiresize dot com 2
ncrunner
Neil
Raleigh, NC
Ford Bronco
Looks really useful. Hopefully they will add the 2025 4Runner soon.
2025 TRDOR 4Runner
The one thing you have to keep in mind with comparing wheel offset on tiresize.com is there is no field for wheel width. So if your wheel width is the same then this will work no problem. If you're going from a 7.5" wheel to an 8.5 the offset will not be accurate.
1010tires has a tool that I use for this but it does not have the tire calculator built in. You could do the math to factor out the wheel width and just add/subtract the offset to compensate for this, then enter into the tire size.com calculator.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator?srsltid=AfmBOoqDELseTUMtiHMjZ9c-zp19KgxPxNxhRTBXnmcqtLRzIQmVrllA
