Max Tire Size for TRD wheels?
MIkeD- I know you have a lot of insight into this. Sounds like a 275 70 18 on the optional TRD flat black (45 offset) would work on an ORP with no lift and no trimming? And if I level out the front even better.
Yep
Am virtually certain
Flyfisher
Allen
5th Gen 4Runner
If you're asking about the TRD Flat Black Option +45 wheels (not TRD PRO), I have an ORP with stock suspension (for now). Running five Toyo Open Country AT3 E-rated LT 275/70 R18. Not sure if a 285 in this tire would rub, but this Toyo 275 (33.2") appears to be the limit for stowing the spare without mods or deflating.
Check the actual diameter for the tires & sizes you are considering.
Our ORP (non-hybrid) has TRD flat black +45 PIO wheels.
On stock suspension, running five Toyo Open Country AT3 E-rated LT 275/70 R18. This Toyo 275 (33.2") appears to be the limit for stowing the spare without mods or deflating.
quick question,,,,,even though the "LT" tires are not speed rated for the ORP's, have you experienced any vibrations or balancing issues with those tires?????
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Speed rating for our Toyo Open Country AT3 E-rated LT 275/70 R18 is "S" or "Up to 112 mph". My max speed is occasionally 85 mph. So I'm not expecting any catastrophic failures due to over speeding. With nearly 2000 miles, no vibrations or balancing issues.
For 5+ years on my 2020 Ranger, I ran Toyo Open Country AT3 E-rated LT 265/70 R17 which are also speed rated "S" or "Up to 112 mph". Never had a failure, flat, vibrations, or balancing issues.
Flyfisher
Allen
5th Gen 4Runner
Ok, thanks for responding,
I was asking cause, I have a 2021 TRD OFP with LT tires from Les Schwab and had to re-balance my tires (often) due to steering wheel vibration. Could be a manufacturer issue, anyway, I am seriously considering going with the Toyo LT tires. Thanks again, Allen
RunnerRocks
RedDog
Nature
Abnormal tire wear can lead to vibrations and rebalancing.
How's your alignment?
Flyfisher
Allen
5th Gen 4Runner
The alignment is fine and tire wear is actually pretty good.....I had my tires rotated and balance every 5K.......thanks again....
