Templates for Homemade Base Plate in Second Row Delete
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
I am contemplating drawers in the back cargo area but want my fridge in the center of the SUV. Would love to build a base plate I could bolt to the second row seat mounts (once I remove the second row). I want to build something flat that I could mount a fridge slide to so the fridge slides out the second row open door. Anybody built something like that?
mcd_ovrlnd
mcd_ovrlnd
SE PA
@4funner i noticed maybe you did this. You have any measurements for what you built?
mfoga
Socal
r4unner
I looked into this but found it wasn't going to work. The problem is you need it really high to be able to slide it out and not quickly hit the door. I found it would need to be above the armrest to be far enough from door based on shape of opening to get a lot of slide out but then I would need a step stool to get in fridge.
mcd_ovrlnd
mcd_ovrlnd
SE PA
thanks for this feedback. very helpful.
TRD_Alex
New York
If you're unable to find a template, you can always use CAD! (Cardboard Aided Design)
Get a large slab of cardboard that can fill the entire rear of your 4Runner and cut around everything. Pull it out, lay on a sheet of plywood, trace it on, cut with jigsaw. Once you have the plywood cut you can take measurements for anything else you want to add.
You'll likely need to make it out of 3 separate pieces then screw them together once placed inside.
