Temperature control stuck
germanjli
German
2025 4 Runner
I've noticed that the temperature control gets stuck on two degrees only. I found it after setting the temprature control from the phone on remote start.
For example I set the temperature to 70 degrees when I remote start the car, it does start with the temperature at 70, but if I use the temp adjustment control know, the temperature goes between 70>71>70>71...
Has any one run into this issue?
Then I'm not able to get out of this limitation on temperature.
2025 2026 4runner 6th gen Temperature control stuck Screenshot_20250609_111949_Toyota
lol be happy you even have 70F. before this you had no ability to even set a temp via the app
