Spare tire issue - wear marks on sidewall from rubbing against frame
HydeQc
HydeQc
Francis
Quebec
2025 4R TRD Offroad Premium, 1998 Range Rover p38, 1968 Land Rover Series IIa
Here's my permanent bushfix. :) I used a windsheild washer container as the material had the perfect ratio of resistence / slipperiness. Added a layer of rubber on each side. Tiewraps to hold it in place (just to make sure...). I will do a few hundred km and do an inspection, but I'm confidend.
2025 2026 4runner 6th gen Spare tire issue - wear marks on sidewall from rubbing against frame 20251102_130334
2025 2026 4runner 6th gen Spare tire issue - wear marks on sidewall from rubbing against frame 20251102_131502
2025 2026 4runner 6th gen Spare tire issue - wear marks on sidewall from rubbing against frame 20251102_134702
JasonNewYork
Jason
Franklin Square, NY
Honda CRV
HydeQc, I like your solution. I was curious if I take the lazy approach and stick some adhesive foam to the frame rails, would it prevent the tire from rubbing though? I attached a pic of what I have in mind. You can purchase up to 1" wide with 3M tape (the best I think).
2025 2026 4runner 6th gen Spare tire issue - wear marks on sidewall from rubbing against frame 71JuWvf3xRL._AC_SL1500_
