Service manuals?
Joestac
Hacksaw
az
2025 4runner TRD-ORP
Thank you!
It begins at the 22m37 time stamp if anyone else is looking for it.
(and thanks to Nodak for pointing out its existence in the first place)
left / right dash speaker ? need to get A pillar plastics removed first
and of course you can't click those added info links unless you are subscribed
and logged into techinfo...
Last Modified: 05-29-2026​
6.11:8.1.0Doc ID: RM100000002OTP1
Model Year Start: 2025​
Model: 4Runner​
Prod Date Range: [12/2024 - ]​
Title: AUDIO / VIDEO: INSTRUMENT PANEL SPEAKER: REMOVAL; 2025 - 2026 MY 4Runner 4Runner HV [12/2024 - ]​
REMOVAL
CAUTION / NOTICE / HINT
HINT:
  • Use the same procedure for the RH and LH sides.
  • The procedure listed below is for the LH side.
COMPONENTS (REMOVAL)
2025 2026 4runner 6th gen Service manuals? E549517N01
ďż˝
Procedure​
Part Name Code​
2025 2026 4runner 6th gen Service manuals? Z101297
2025 2026 4runner 6th gen Service manuals? Z101188
2025 2026 4runner 6th gen Service manuals? Z101187
1​
FRONT DOOR OPENING TRIM WEATHERSTRIP LH​
62312B​
2025 2026 4runner 6th gen Service manuals? Z101187​
2​
FRONT NO. 1 PILLAR GARNISH COVER LH​
62216B​
3​
FRONT PILLAR GARNISH ASSEMBLY LH​
62212B​
4​
PILLAR ASSIST GRIP ASSEMBLY​
74680​
5​
FRONT PILLAR GARNISH ASSEMBLY RH​
62211U​
6​
NO. 1 INSTRUMENT PANEL SPEAKER PANEL SUB-ASSEMBLY​
55408F​
7​
FRONT NO. 2 SPEAKER ASSEMBLY​
86160P​
8​
NO. 1 SPEAKER WITH BOX ASSEMBLY​
86150​
9​
NO. 3 INSTRUMENT PANEL SPEAKER PANEL SUB-ASSEMBLY​
55474E​
10​
NO. 2 SPEAKER WITH BOX ASSEMBLY​
86150B​
*A​
for LH Side​
*B​
for RH Side​
*C​
for 14 Speakers​
*1​
FRONT PILLAR ASSIST GRIP PLUG​
â—Ź​
Non-reusable part​
PROCEDURE
1. REMOVE FRONT DOOR OPENING TRIM WEATHERSTRIP LH
HINT:
Pullback the front door opening trim weatherstrip LH so that the front pillar garnish assembly LH can be removed.​
Click here 2025 2026 4runner 6th gen Service manuals? Z101297
2. REMOVE FRONT NO. 1 PILLAR GARNISH COVER LH (for LH Side)
Click here 2025 2026 4runner 6th gen Service manuals? Z101297​
3. REMOVE FRONT PILLAR GARNISH ASSEMBLY LH (for LH Side)
4. REMOVE PILLAR ASSIST GRIP ASSEMBLY (for RH Side)
5. REMOVE FRONT PILLAR GARNISH ASSEMBLY RH (for RH Side)
6. REMOVE NO. 1 INSTRUMENT PANEL SPEAKER PANEL SUB-ASSEMBLY
7. REMOVE FRONT NO. 2 SPEAKER ASSEMBLY
2025 2026 4runner 6th gen Service manuals? E549518
8. REMOVE NO. 1 SPEAKER WITH BOX ASSEMBLY (for 14 Speakers)
2025 2026 4runner 6th gen Service manuals? E549519C01
2025 2026 4runner 6th gen Service manuals? V100135
Push​
2025 2026 4runner 6th gen Service manuals? V113147
Remove in this Direction​
9. REMOVE NO. 3 INSTRUMENT PANEL SPEAKER PANEL SUB-ASSEMBLY (for 14 Speakers)
Click here 2025 2026 4runner 6th gen Service manuals? V113147
10. REMOVE NO. 2 SPEAKER WITH BOX ASSEMBLY (for 14 Speakers)
2025 2026 4runner 6th gen Service manuals? E549520
2025 2026 4runner 6th gen Service manuals? footer.left
2025 2026 4runner 6th gen Service manuals? footer.right
here is one part you likely need
42. REMOVE NO. 1 INSTRUMENT PANEL SPEAKER PANEL SUB-ASSEMBLY
2025 2026 4runner 6th gen Service manuals? B730444C01
Remove in this Direction (1)​
2025 2026 4runner 6th gen Service manuals? V113148
Remove in this Direction (2)​
just saying... what do you want to do to your 4runner w/o busting stuff, 30 bucks is access to all the good details
