wavejd
Jim
Boston
Hi All - I am a relatively new owner of a ‘25 4Runner ORP / Hybrid and since this forum has been so helpful to me, I wanted to share some details on a recent mod related to a sleeping platform that I built. I have been researching different bed platform ideas to work with the non-flat rear area of my 4Runner hybrid. Use case is overnight sleeping when on ski and other trips (where I prefer to just sleep in my 4Runner vs. tent, hotel etc.
I looked at the many different pre-built platform and cot ideas that are out there. However, I just wasn’t comfortable with the cost or design of pre-built solutions so I decided to try to build something myself in a low cost manner. Here are the requirements for my build:
  • A width that would maximize the space for one person yet still allow the use of the rear seat behind the driver’s seat (either by a 3rd passenger or by me when trying to get dressed in the morning before skiing).
  • A length that would accommodate my 6’2” frame but not require the front passenger seat to be pushed up too far
  • Easily removable when not in use (i.e. nothing that needed to be bolted in or required vehicle mods).
Parts list:
  • 4' x 8' x 3/4" sheet of birch plywood (qty 1 - about $100 depending on where you buy it - note you could use a cheaper plywood material but I wanted something something with a smooth, sandable surface)
  • 5" x 1/2" pipe nipple for feet legs (qty 2 - about $10 total - note if you want to accommodate different leveling situation, you can also get some 4” and 6” pipe nipples)
  • 1/2" Pipe flange for feet (qty 4 - about $20)
  • 3/4" x #12 wood screw to attach flange to plywood (qty 8 - about $2)
  • Stain of your choice (about a pint should do it - $10 unless you have leftover material from another project like I did)
Total material cost for platform: under $150
The only other cost was for a sleeping pad (selected for optimal fit of the platform dimensions; about $60; other options will work - If you are a frequent camper, you already have a sleeping bag and maybe also a sleeping pad.): https://www.amazon.com/dp/B0BL6H7Y2J?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Tools required:
  • Table or circular saw to cut plywood sheet down to size
  • Jig saw to round the edges of platform
  • Hand or power sander to smooth out edges
  • Screwdriver to mount flanges for feet
  • Tape measure
  • Level
Time required: Less than 2 hours (not including time required for stain to dry)
Dimensions of platform: 74” long x 27” wide (you might be able to make it a bit longer if you are willing to push up the passenger seat a few inches)
Below are some pics of what I built. Tried it out for an overnight driveway stay this weekend and I am happy with the outcome. Can’t wait to use it on a real trip. Here are the details. Happy to answer any questions you may have!
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid bag
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid mat-1
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid mat-2
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid ni
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid flang
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid flange-dimensions
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid flange-mount
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid plat-front-seat
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid plat-left-seat
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid plat-level
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid plat-level2
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid plat-right-seat
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid plat-round
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid plat-seat-well2
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid feet
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid plat-init-cut
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid feet-well
2025 4runner 6th gen Homemade sleeping platform for my ORP Hybrid 26727-7ed61eb53f0fcdc144052627d2a6a0c6
MartyMcFly
This is awesome! Thanks for so many pictures and info!
6GenChad
Tommy
San Diego
This is very useful, thanks!
Cranberry
Dan
Manitoba Canada
You nailed this design man. Absolutely awesome. I ran a similar up on my Gen 5 and have been trying to figure out how i could replicate it on the Gen 6, you nailed it 100%.
Great work!
thank you so much for sharing this.
wavejd
wavejd
Jim
Boston
Thanks all for the good feedback. Couple of other points I forgot to mention:
1. My choice of 5" pipes for the legs was done because that is what it took to have it level on a flat level driveway surface with the hybrid battery. If your parking area is not level, the pipe can be threaded in or out of the flanges to give you about 1/4" of adjust on top and bottom. If you don't have the hybrid battery (and the increased floor height that comes with it), you can just get longer pipes.
2. If you don't like the idea of flanges on the bottom of the platform feet (the side that touches the 4R floor), you can also use rubber feet that you put on the bottom of chair legs. I close the flanges because it gives me some more height adjustment and it spreads the load out a little bit more for stability.
Happy building!
scorp
None
Looks great, I may steal your pipe leg idea, but move them to the outside and maybe add more. I rigged a quick platform, but just used 2x4's for support and didn't fasten it, as it was temporary. That was 3 weeks ago, and it's still in the rig... The 2x4 supports run along the side, so I can put a decent sized plastic storage box underneath the platform.
nice work!
wavejd
wavejd
Jim
Boston
nice work!
Yes, you could certainly place the pipe legs in a different location (to allow for better placement of stuff underneath the platform). I chose the location I did for weight distribution and placement in the middle of the platform to balance out support. However, if one uses 3/4" plywood (as I did), you really don't have to be too picky about the placement (since the thickness of the plywood gives more than enough support to prevent bowing). I too thought about the wooden support approach you used but I like the screw on / off approach that the pipe legs give. Lots of different ways to optimize this idea!
JDub
Jerry
Las Vegas
2025 4Runner ORP
what is the brand of the sleeping mat?
wavejd
wavejd
Jim
Boston
MartyMcFly
828findadventure
Tacoma & Tundra
It would be great if the 2nd row were easily removable.
Cranberry
Dan
Manitoba Canada
Parts list:
Tools required:
  • Tape measure
  • Level
Hey friend,
I am just starting my build camp system and love your sleeper so much im pretty much replicating it (few minor changes but ill update this thread with my set up in a few weeks).
Quick question though, can you do me a huge favour and provide a measurement from top of bed board to ceiling inside cab? I run a similar design of a bed system on my gen 5 and want to get an idea if your design has less or more head room when inside the 4Runner for sleep.
Thanks!
wavejd
wavejd
Jim
Boston
Hey friend,
Thanks!
Sure - happy to help....I'm away from my 4runner until Saturday but will take the measurement then and send it over.
C/G
Cary
Orange County, CA
Love it - very helpful.
C/G
Cary
Orange County, CA
Parts list:
Tools required:
  • Tape measure
  • Level
As mentioned above great job.
It looks like you use this platform "as is" - no storage needed (inside the 4R). Did you consider a collapsable/ modular type design to optimize storage space when traveling?
C/G
