Heritage Grille Swap - Camera Recalibration?
SummitSeeker
2026 4Runner ORP
Here’s what someone told me about the Tacoma calibration:
Enter Accessory Mode
Close all doors and windows.
With your foot off the brake, double-tap the start/stop button.
The infotainment screen will boot.
Activate the Hidden Service Menu
Mute the audio (turn the volume all the way down).
Navigate: Settings → Display → Screen, then turn off the display.
Swipe left to right five times, then right to left five times.
Ignore any prompt like “Touch to turn screen on.”
If it doesn’t work, tap to re-enable the screen and repeat.
Upon success, you should see the Service Menu pop up.
Tacoma4G
Adjust Camera View
Go to Function Check → Camera Settings → View Adjustment.
If an option is greyed out, long-press it (~5 seconds) to activate.
Tap Next, and the bird’s-eye 360 view appears—here you can tweak the front camera alignment.
Tacoma4G
Save & Exit
After adjustments, select OK to save and then exit the Service Menu.
On your next ignition cycle, confirm the Service Mode prompt to finalize
Has anyone confirmed this works?
Mad Ghost
Justin
Wylie Texas
4Runner ORP and Avalon
your going to need and do a search someone for sure got it to work and even included pictures of the service instructions that showed how to calibrate it.... it involved puting marks on the pavement at particular spots and then adjusting in the 4Runner
