Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations
Looking to hookup my CaliRaised dual amber/white LED lightbar. I can't use one of my AUX switches because it is a dual switch so I need to use their wiring harness to hook to the engine bay positive terminal.
Is it the thing under the red flip up in the relay box? If not, anyone know where it is? I know I seen a thread on it here but can't seem to find it.
Never mind, found the thread.
https://4runner6g.com/threads/power-ground-locations-hybrid-4runner-2025-6th-gen.681/
2025 4runner 6th gen Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations img_0966-jpe
In the 2025+ Toyota 4Runner Hybrid (6th Gen), the 12V auxiliary battery is located in the rear cargo area, specifically on the driver side behind the driver-side rear tire. This placement is different from the gas-only models, where the 12V battery is located on the passenger side in the engine bay.
You have a couple of options for alligator clip placement and grounding purposes in the hybrid engine bay. These power and ground locations are suitable for jumping, compressors, and other 12V accessories.
Power (Positive Terminal) In Fuse Box:
2025 4runner 6th gen Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations IMG_0958a
2025 4runner 6th gen Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations IMG_0960
2025 4runner 6th gen Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations IMG_0972
The positive (+) terminal for jump starting is clearly shown and labeled in the engine bay fuse box on the passenger side. Pop off the fuse box cover, and you will see the red cover to the positive (+) terminal. Flip the red cover open and connect your alligator clips.
Ground (Negative Terminal #1):
2025 4runner 6th gen Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations IMG_0976
Toyota specifies that the negative (-) jumper cable should be connected to the metallic point in the engine bay, not directly to the battery.
“Connect the clamp at the other end of the negative cable to the metallic point shown in the illustration on pages 608–609 of the Owner’s Manual” - pictured above and below in the Toyota owners manual diagram section.
The owner's manual also says:
  • Unpainted metal surfaces: Areas such as bolts or brackets attached to the chassis can serve as grounding points.
  • Existing ground straps: These are often found connecting the engine block to the chassis and can be utilized for grounding.
Ground (Negative Terminal #2):
2025 4runner 6th gen Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations IMG_0971
2025 4runner 6th gen Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations IMG_0978
If, for some reason, your jumper cables or your 12V accessory alligator clips do not reach the metal clip, you can use any unpainted metal surfaces like bolts or brackets attached to the chassis, which serve as solid grounding points. There are 12mm bolts along the inner fender wall in the engine bay a larger 17mm chassis ground bolt under the air intake inlet cover. Remove the air intake inlet cover, and you will see a big black bolt that will provide another suitable ground. This might be a good option if you have large alligator clips that won't bite the small 12mm bolts.
Power and Ground Location Diagrams from Toyota:
2025 4runner 6th gen Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations img_0980-
2025 4runner 6th gen Positive battery terminal location (Hybrid 6th gen) -- Power & Ground locations img_0979-
Who keeps changing my posts? Seems everytime I post a thread it gets changed. Been on a lot of forums over multiple decades and never seen this before.
NYNickET
Nick
South Carolina
2025 Toyota 4Runner ORP
where would you hook up accessories from under the hood?
i am trying to install my AuxBeam Circuit Box under the hood and i can see where to hook up the main positive cable
appreciate any advice. . thanks
