Door Jamb Stickers: Payload Capacity & GVWR Numbers
Administrator
Administrator
Administrator
Staff member
Jay
This was from preproduction Trailhunter 2025 4Runner 6th gen.
Payload: 895 lbs / 405kg
2025 4runner 6th gen Door Jamb Stickers: Payload Capacity & GVWR Numbers door sticker payload 2025 4Runner Trailhunter 6th gen
It's from TFL's video:
mars001
2003 4Runner SR5 4.7 V8
How come it's different than Toyota specs on their own web site?
payload (GVWR - curb weight):
SR5 = 1550 lbs
Limited = 1400
TRD Pro Hybrid = 1050
2025 4runner 6th gen Door Jamb Stickers: Payload Capacity & GVWR Numbers payload
mars001
Oh, ok, the 895 lbs is for TrailHunter!
So, after installing a winch, steel bumpers and gears and supply, there may be room for a single driver and no passenger? ?
4running
TX
2020 4Runner SR5
Looks like @Kokorone's SR5 has higher payload number and higher GVWR vehicle weight than @jerrycaparros TRD Sport, as one would expect.
Kokorone's 2025 SR5:
- Payload: 1160 lbs (reduced 61 lbs for modifications - per yellow sticker)​
- GVWR: 6075 lbs
Jerrycaparros' 2025 TRD Sport:
- Payload: 895 lbs (no view of the yellow sticker for payload reduction for modifications)​
- GVWR: 6395 lbs
the yellow sticker should be added after FIO and PIO are installed. dealer would have to adjust or get a new yellow sticker if they do DIO.
jerrycaparros
Jerry
- GVWR: 6075 lbs
- GVWR: 6395 lbs
Payload on my TRD Sport is lowered by 23 lbs for modifications.
2025 4runner 6th gen Door Jamb Stickers: Payload Capacity & GVWR Numbers e634beb7-5b3d-4a3b-b25c-924edf45260f-jpe
Hacksaw
az
2025 4runner TRD-ORP
There's a still-unresolved issue of the 4runner payload rating (on the sticker in the driver's-side door jamb) being really low, in some of the earlier Youtube videos reviewing the 2025 4runner. It almost seemed like Toyota, early on, was slapping an 895 lb payload sticker regardless of trim level and GVWR/Curb Weight.
Or maybe there were some misprinted labels early on, or whatever reason for the low numbers, I'd like to find out if Toyota has corrected this.
If you've recently taken delivery, could you please post:
1) your trim level,
2) approximately when you took delivery, and
3) the number (in pounds) from the white sticker (in driver's-side door jamb) specifying the payload?
[Edit to add: it's on the sticker that shows the tire pressures. It doesn't actually say the word "payload."
It will say, "The combined weight of occupants and cargo should never exceed xxx lbs."
I'm just looking for the xxx number.]
(optionally you can also post the value from the yellow sticker that makes downward adjustment for the weight of PIO/DIO)
boat
steve
Issaquah, WA
2025 TRD Off road Premium
895 -47 (I assume for the roof rack)
Jakethewhippet1
Geneva, IL
2025 4Runner Off Road Premium
ORP, 895 lbs, took delivery 6/17, yellow sticker -7 lbs for running boards which were only installed option.
