Day time running lights not working
thewanderer
New York
2025 Toyota 4 Runner
Bought a 2025 TRD PRO a year and a half ago. I turned off my day time running lights off from the directional stalk and now they won't come back on. They will work when I put my headlights on but that's it. I went into the vehicle customization and turned if off and back on. restarted the car same thing nothing. Ive played with it multiply times and can't seem to fix this..
If Anyone can help.
Thanks
timberline
New Jersey
2025 TRD Off-Road Premium, 2003 Limited V8
I put the Toyota Owners Manual PDF into Google's Notebook LM, which is AI that only searches documents that you want to search. You can also add resources like this website for cross-reference to anything not in the manual. It will also link to the reference in the response. Here's the results:
The Daytime Running Light (DRL) system on the 2025 Toyota 4Runner automatically illuminates under daytime conditions to make your vehicle more visible to other drivers[1][2]. It is not designed for night driving[1][2].
Illumination Types
  • Bulb-Type Turn Signals: DRLs illuminate using the low-beam headlights running at a dimmer brightness level[2].
  • LED-Type Turn Signals: DRLs illuminate using the parking lights running at a brighter intensity than standard parking light mode[2].
Activation Conditions
The DRLs turn on automatically when all of the following conditions are met:
  1. The engine/vehicle is running[2].
  2. The parking brake is fully released[1][2].
  3. The headlight switch is set to the AUTO or Parking Light position while the surrounding ambient light is bright[1][2].
Note: Once activated, the DRLs will remain illuminated even if you re-engage the parking brake while the engine stays running[3]*.*
Turning Off or Customizing DRL
  • Headlight Switch Control (U.S. Models): You can turn off the DRLs by rotating the headlight control stalk to the DRL OFF position[3][4].
  • Vehicle Settings Menu: DRL operation can also be toggled ON or OFF through the customization settings in the Multi-Information Display (MID) or the Multimedia screen[5][6].
thewanderer
New York
thanks for this information
Today I pulled up to a store with reflective glass. I noticed the date time runningg lights were on. the signal stalk switch was on Auto the day time. light switch was on and in customization lights was on. But no lights on the dash saying they were on (they used the on). I turned the daytime running light switch off on the stalk nothing happened and they stayed on. I turned off the the day time running lights off on the vehicle customization and they turned off.. Weird
shine
Seattle
The DRL will not turn on when the transmission is in park, so it makes sense that you'll see them when you pull up to something reflective.
I don't remember there being any dashboard light that indicates the DRLs being on.
Vincenzo
Southeast
I believe the headlights are the DRLs. I went through this, myself. Are looking for a “Raptor” effect? Amber lights?
only some models with the SR5-type single projector headlight
and incan turns.... have drl as a dimmer low beam
the other type of headlight has independent DRL
thewanderer
New York
thanks for all the help
Its strange but my day time driving lights were always lit when I started the car and I had a light on my instrument panel telling me they were on for a year and a half. Now my day time driving lights behave as in the post from timberline.
