rutsnext
British Columbia
2025 4Runner ORP
Decided to capture all the info I had been looking at on tire and wheel options I was considering. Used wheel-size.com for stance and scrub radius impact. Sharing in case it's useful to anyone else considering their options. I checked it, but I'm not guaranteeing I copied everything onto the spreadsheet correctly.
TRD upgrade wheel is PTR56-35242-F1.
Weights are in lbs. Tire measurements and offset are in mm.
2025 2026 4runner 6th gen Comparison of different wheel and tire size options + difference to size, stance, scrub radius, weight vs stock ORP wheels 2025 4Runner wheel sizes
AZTrail
2026 TRD Off-Road Premium Everest
In 2026 BFG KO3 LT265/70R18 Load Range D is scheduled to come out. This tire will weigh less than the current Load Range E tire from BFG and should provide a little softer ride. Too bad a BFG Load Range C tire is not on the schedule for 18" wheels. On the 5th gen the BFG KO2/3 Load Range C on 17" wheel was a great tire. Very strong yet compared to load range E was a lot lighter and softer ride.
rutsnext
British Columbia
2025 4Runner ORP
Ya, A few lighter weight options would be nice, especially in 18". I originally looked at a Load Range C in 285/70/R17 but there was no weight savings on the Toyo or Falken so I hide that column.
ifunlisted
AZ
Has anyone been able to find wheel weights (not tire) for the stock trims. Interested to see the weight difference between the 18" and 20" wheels.
