Any upgrade on the rear window wiper? Bigger wiper options?
Motosprout
Adam Danyeur
Flathead Lake Montana
Rainy weather and dirty road grime builds up on rear window. When using the rear wiper the small area just doesn't give enough of a view behind. Can I use a bigger blade to clean a larger area?
I didn't get the trailer package so I didn't get the rear view mirror with camera option. Probably wouldn't help since the back is covered in road grime anyways.
Maybe I shouldn't care what's behind me....
sstarrx2
No...whatever you get would have to fit back up into its housing...so short answer is no.
vudo90275
Vu
2008 Toyota Sequoia 4wd
I don’t think a longer wiper would fit the rear window wiper since the glass height is so short. The digital mirror camera is mounted at the license plate area and not behind the rear hatch glass so it is not obstructed by dirty glass surface. It has a built-in washer nozzle directed at that camera to clean it in the event of dirt buildup obstructing the rear view. The only gripe I have with that camera is its position which would be block if tire or bike carrier is mounted to the hitch. I think Toyota could have engineered it to fit behind the rear hatch in an area that can be wiped clear with the rear wiper.
TrdProGirl84
Don’t think they’re is an upgrade for that. All you can do is buy a new wiper blade
the wiper resting / stowage area will not accommodate a larger wiper assembly since it retracts into the rear wing area. its cut out to fit the wiper arm exactly if i remember correctly.
same issue with the 5th gen 4R
