- Thread starter
- #1
A lot of dash cams are designed around the daily commute. Built with people who camp and road-trip in mind, the Wolfbox G900 Pro 4K Smart Mirror Dash Cam is built around the real demands of camping and road-tripping.
Here's what it was designed to cover.
Campsite security when no one's in the vehicle
Trailhead parking lots, overnight stops, the car parked on the trail while the day is spent on the move, these are moments when the vehicle is unattended for hours.
The G900Pro supports 24/7 parking monitoring with a hardwire kit installed, in two ways:
Storage that actually lasts a multi-day trip
The G900Pro accepts up to 512GB and runs loop recording by default, writing 1/2/3-minute clips and overwriting the oldest files automatically. Crash footage gets locked into a protected folder automatically, so loop recording can't touch it.
Backing up a big rig into a tight campsite
The G900Pro's rear camera installs inside or outside the vehicle, and the 12-inch mirror display switches to a full rear view. Full-screen or split-screen, with adjustable reversing lines, so it's easier to gauge distance.
The dark forest road home
Some camping routes are unlit.
The G900 Pro runs a Sony STARVIS IMX678 sensor with a 1/1.8" large sensor size — built to keep footage readable and license plates recognizable in low-light conditions.
Rainy weekends and wet gear
The G900Pro's rear camera is designed to install inside or outside the vehicle, so it can be mounted externally your car for the best rear view.
It's rain-ready for outside mounting, a wet weekend at the campsite doesn't interrupt coverage.
Summer heat in a parked car, winter cold at the campsite
Dash cams that give up at temperature extremes are surprisingly common.
The G900Pro has a operating temperature range of -4°F to 158°F (-20°C to 70°C) — covering basically every climate a North American or UK road-tripper will park in.
Daily commute and weekend camping trip are not the same use case. The G900Pro was designed to fit the camping and road-trip life specifically. The full breakdown above is exactly what the dash cam was built to do.
Full specs and availability?Official product page here: https://wolfbox.com/products/wolfbo...dash-cam-smart-mirror-with-starvis-678-sensor
If you have questions about the installation, the parking mode settings, or running this on a van or trailer, drop them in the thread.
- 12H / 24H Time-Lapse Recording: continuous timelapse for the duration you set, so one overnight stop doesn't fill the SD card.
- G-Sensor Trigger Recording: wakes the moment an impact is detected, then saves that clip to a protected folder that loop recording won't overwrite.
