- First Name
- John
- Joined
- Apr 9, 2024
- Threads
- 50
- Messages
- 70
- Reaction score
- 74
- Location
- St. Louis, Missouri
- Website
- www.diodedynamics.com
- Vehicle(s)
- 2024 Toyota 4Runner
- Thread starter
- #1
Stage Series Infrared is here. Built for use with compatible night vision systems, the new lineup includes SS3, SSC1, SSC1 Dual, and Follow-Me options with purpose-built IR performance for a wide range of off-road and nighttime applications.
Infrared lighting is only useful if it works with your equipment and your environment. Stage Series Infrared gives you multiple wavelengths, power levels, beam patterns, and form factors so you can choose the right setup for your vehicle and dial in the performance you actually need.
Our IR-specific filtered lens helps minimize unwanted visible glow at the light source, giving you a more discreet infrared setup. Choose between 850nm and 940nm options where available to match your night vision equipment and preferred visible signature.
Stage Series IR optics are engineered and produced in-house for controlled beam performance through night vision. Each optic is designed around the unique demands of infrared output, helping put usable illumination where you need it instead of simply chasing raw output.
More IR output is not always better. Too much intensity can overwhelm night vision equipment and reduce usable visibility, so Stage Series IR gives you high and low power modes plus PWM and variable-voltage dimming to fine-tune output for your setup, terrain, and conditions.
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
Experience. After over a decade in business, Diode Dynamics is one of the most trusted names in automotive LED lighting. We directly manufacture and engineer our own products in the United States using globally sourced materials, allowing for higher quality and performance, with the newest and brightest LED technology. No matter what you're driving, we pride ourselves in offering only the best possible LED solutions. Please contact us if you'd like to discuss your lighting project!
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: [email protected]
Phone: 314-205-3033
Forum Member Benefit: All forum members are eligible for a free US shipping code for orders. Please send us a direct message for the exclusive code and save on any new or future order.
John C.
Diode Dynamics
