chrismacc
chris
dallas, Ga
I am not very good at writing how to’s and what not but I wanted to write up a little something and post a picture and video. It is a lot easier than it looks. I highly recommend this product, you look at these screens wrong and they get scratched up.
1️⃣ Mix your soapy water
A little dish soap + water in a spray bottle. Doesn’t need much soap at all.
2️⃣ Clean the screen
Wipe the screen down with the soapy water mix so there’s no fingerprints, dust, or smudges. Spray again and wipe it with the provided rubber scrapper tool.
3️⃣ Spray the screen AND the sticky side
This is the trick that makes it easy. Spray the screen with plenty of soapy water, then spray the sticky side of the ScreenProTech before you put it on. This lets you slide it around and get it lined up perfectly.
4️⃣ Line it up
Place the protector on the screen and slide it into position. The soapy water gives you time to adjust it.
5️⃣ Squeegee the water out
Use the included squeegee (or a microfiber with a card behind it) and push all the water and bubbles toward the edges. Take your time here — this is what makes it look clean.
6️⃣ Wipe and let it dry
Give it a final wipe. Any tiny bubbles or cloudy spots usually clear up after it dries for a few hours.
That’s it! If you mess up, just peel it back up, spray again, and reset it. Super forgiving install. They also have an option where you can purchase the insurance and that basically means an extra set is provided just incase you mess it up. I purchased it just to have an extra set.
If you have any questions, please don’t hesitate to ask.
The pictures
2025 4runner 6th gen Screenprotech screen protector film cover install on my 4runner (DIY) IMG_4818
2025 4runner 6th gen Screenprotech screen protector film cover install on my 4runner (DIY) IMG_4817
2025 4runner 6th gen Screenprotech screen protector film cover install on my 4runner (DIY) IMG_4826
2025 4runner 6th gen Screenprotech screen protector film cover install on my 4runner (DIY) IMG_4823
2025 4runner 6th gen Screenprotech screen protector film cover install on my 4runner (DIY) IMG_4819
the screen protech bottle already comes pre-fill with soap for the bottle size, just add water if i remember correctly from the instructions.
chrismacc
chrismacc
chris
dallas, Ga
Yes it does.
danimaldaisy
Dan
San Bernardino
6th gen trd sport
The original screen protector when my 4Runner was shipped is what I’m using. I’m shocked it had no bubbles.
mightysnopants
chicago
6th Gen 4Runner TRD Offroad i-FORCE MAX
Your start button looks different (better). Did you mod it? If so, with what and where’d you get it?
