BerkRunner
Berk
2025 4Runner SR5 4x4
I finally installed the @roughcountry fender flares to match the gloss black paint and so far I’m really happy with the look. I’ll eventually swap my tires out for some wider all terrain tires and the RC flares will look perfect with the wider tires (I’m just too cheap to waste perfectly good tires, lol).
The install wasn’t difficult, just time consuming learning the lessons of a first time installation. I made a video of the installation for any of you thinking about installing these yourself, hopefully it’ll save you some time. Total installation time was about 5-6 hours. The second set took me half the time of the first set (no surprise there). If you’ve installed something similar it may go faster. There were a few steps that RC left out of the instruction manual but nothing critical.
Let me know how your install goes if you install these also.
2025 4runner 6th gen Rough Country Fender Flare Installed rough country fender flares 2025 4runner 6th gen
2025 4runner 6th gen Rough Country Fender Flare Installed IMG_1875
2025 4runner 6th gen Rough Country Fender Flare Installed rough country fender flares gloss black
2025 4runner 6th gen Rough Country Fender Flare Installed IMG_1871
2025 4runner 6th gen Rough Country Fender Flare Installed IMG_1824
2025 4runner 6th gen Rough Country Fender Flare Installed IMG_1870
vs. stock fender flares
2025 4runner 6th gen Rough Country Fender Flare Installed IMG_1826
2025 4runner 6th gen Rough Country Fender Flare Installed IMG_1823
Van Solo
Van
Calgary / Canada
Very well done sir,
Can you tell me the space from wheel centre cap to edge of the Flare please??
It appears to be substantial?
Are you going to change wheels and tires to decrease that and flush them to new flares?
Laszlo
Jennifer
WA
2025 Toyota 4Runner TRD Off Road Premium
Very nice! We were looking at the Rough Country flares and were weary on what the black gloss would look like. They look good and like you said, will look better with wider tires but I too don't like to waste good tires so that would be a wait for me as well. Thanks for the video!!
BerkRunner
BerkRunner
Berk
Very well done sir,
Thanks! I’m not sure if I understand what you’re asking to measure. The flare RC extends horizontally away from the body 2 inches more than the stock flare. From the center of the stock rims to the bottom of the flare is 20”. Let me know if that’s not what you’re asking for.
BerkRunner
BerkRunner
Berk
You bet. Hope it works out for you if you get them.
Van Solo
Van
Calgary / Canada
I’m trying to see how far the wheels are from the fender edge how much overpoke from the wheels edge to the outer fender line.
Griffin27
So Cal
2025 4runner Limited
I highly recommend them as well. Pretty painless install. I'm running mine with 18" TRD Pro rims and Nitto Terra G3 275/70/18. They look great and reduce the tire poke for sure. They are even wider that the stock TRD PRO fenders.
Great install Video
2025 4runner 6th gen Rough Country Fender Flare Installed best
2025 4runner 6th gen Rough Country Fender Flare Installed best2
2025 4runner 6th gen Rough Country Fender Flare Installed IMG_3633
2025 4runner 6th gen Rough Country Fender Flare Installed o[o
2025 4runner 6th gen Rough Country Fender Flare Installed IMG_3375
BerkRunner
BerkRunner
Berk
Great install Video
That looks really nice with the wide tires. I’m definitely gonna have to upgrade my tires now.
Van Solo
Van
Calgary / Canada
Great install Video
How much do the fenders measure past the tires edge on your setup please? So what's the feeder poke past the Edge of the tires?
Van Solo
Van
Calgary / Canada
Let me ask the question a different way,
So normally we look at wheel poke because the wheels stick past the fenders?!
Now it appears that the fender pokes more than the wheels?!
What I am asking is how many (Inches, CM or MM) does the fender pass the Tires ?
Can you both place a measure tap on the tire and tell me when it reaches the Fender's Edge so we know what offsets required to flush them front and rear please?
BerkRunner
BerkRunner
Berk
If I measure from the center of the front tire to the edge of the front flare it looks like 6 3/4 inches. If you need more specific measurements just take whatever measurements with the OEM flare and add 2 inches. The RC flares extend an additional 2 inches from the OEM ones.
Van Solo
Van
Calgary / Canada
Okay, Thanks
However, They should only extend 1 3/4" according to them?
Might go a Different route.
BerkRunner
BerkRunner
Berk
Okay, Thanks
yeah that’s pretty close. The 2” measurement is in a picture on my original post. It could be closer to 1 3/4” at second glance.
