- Thread starter
- #1
Like many on this forum, I’ve done a few upgrades, deletes, and personalizations to my 4Runner. Very happy with the ORP and my changes so far…
- Westcott Preload Collar Lift (2.5” front, 0.75” rear) - reduces leaning in corners and diving while braking in addition to leveling and increasing ride height for off-road use.
- Nitto 275/70 R18 Tires (116 Load Index) - 33” tires with much less road noise than stock Michelins (also 116 Load Index). Very happy with these tires and look forward to getting off the pavement soon.
- TRD Pro Wheels - going from 7.5” (+55 mm offset) stock ORP rims/tires to 8.5” (+20 mm offset) rims with the wider Nitto tires resulted in sidewall being 1.58” farther out than OEM setup. Before the Westcott lift this wheel/tire configuration rubbed on the OEM front mud flaps (when steering while accelerating/braking), so I removed front mud flaps. Toyota Parts: PT998-89210-F2 (wheels), 42607-76020 (valve stems with TPMS), and PT998-89210F2 (TRD center caps with red circle).
- Direct Wired my Valentine One Radar Detector - Reused existing radar detector and mounting hardware to attach to Premium Mirror; easy to tap into rearview mirror power. I’ve used/reused Radar Mount brand on multiple vehicles (amazon.com).
- Toyota Premium Horns - One of my favorite DIY upgrades, for sure — super easy and worth every penny when someone cuts me off on the freeway.
- Removed Front Air Dam - worth the hit in fuel economy/range to me.
- TRD Skid Plate - provides additional protection and appearance upgrade vs. ORP plastic version. Toyota Part: PTR60-35240.
- Red Toyota Tow Hooks - another easy DIY upgrade; mostly for looks (I admit). Toyota Part: PT974-35250.
- Applied Matte Black Overlay to Toyota Front Logo - previously the only chromed logo; this requires almost zero skill/effort. Toyota Part: PT948-35245-02.
- Carista - made a few personalizations via OBD-II interface, including making the turn signals louder (I’m hearing impaired).
- Redline Tuning (QuickLIFT Plus) Hood Struts - first upgrade I did; very easy DIY.
- OEM Rack Cross Bars - removed due to wind noise; easily re-attached when needed.
- Lasfit 7443 LED Front Turn Signal Lights | T3 Series (Switchback) - very easy DIY safety improvement; much brighter than OEM bulbs.
- Lasfit Floor Mats - nice mats so far.
- TRD Windshield Sunshade - tried two sizes and am happy with this one: Toyota part: PTQ24-35230.
- Braun Pocket Floodlight (750 Lumen) - Mounted with velcro in empty cubby in dashboard when driver’s door is open (see pics, including translation of Morse code). $29.99 at Harbor Freight.
- OEM Rims/Tires - Sold easily on FB Marketplace to a local SR5 owner to help offset upgrade expense.
