Off road with front sway bar unbolted
wyndzer
NC
25 4Runner
Has anyone unbolted the front sway bar while off roading? Curious what difference it made. I unbolted my links and it seems that the bar won't interfere with anything.
ACJ
Portland Oregon
2026 Toyota 4runner TRD Off-road i-force Max
I'm not an aggressive off-roader but I believe it really depends on what you are doing. If you find yourself with only three wheels on the ground it might put the fourth one down.
NB-4Runner
Marc
New Brunswick, Canada
2024 Tacoma TRD OR 6M
You can watch this and decide after:
Note, the above is a Tacoma, 4Runner has a shorter wheelbase, so results will be different, but same logic.
wyndzer
wyndzer
NC
25 4Runner
Probably did not word it right. I am familiar with what it does.
I’m looking for feedback from anyone that has done it on a 6gen 4Runner. Real world feedback.
HVLA
Lexus
Unbolt it and hit up a curb and post pics. You can be what users find when looking for the answer you are seeking.
Climbandroll
Va
Curious as to how you went about disconnecting.
I recently disconnected during suspension work on the ground (no lift; just ramps, bottle jacks, stands). Slight slope widthwise in flattest lengthwise stretch of my driveway so makes sense sometimes to lift lower side. Did passenger side work first with only that side frame and rock slider supported. Not enough forethought about weight/pressure on driver side of sway bar. Was enough pressure on the link that the bolt caught/binded in link housing after threaded end backed free of the front side of its LCA mount. Required manipulation of LCA mount position relative to sway bar link to relieve pressure enough to free link bolt. Fortunately, no thread damage. Required finesse to get bolt back thru during reassembly with due caution for thead care. Luckliy got it without changing the jack stand situation.
For driver side, supported whole front end with frame and sliders on stands. Much easier to remove sway bar bolt that side. Bit of resistance from weight of passenger side wheel (which I had already put back on because it sat overnight). Considered taking passenger wheel off prior to starting driver side work but figured I'd see how much trouble first.
Did you raise/support the entire front end when you took your link bolts out of each side? Both front wheels off too? Seems like this is the way for both removal and reinstall.
I'm headed on a challenging off-road trail on Saturday and plan to experiment on Friday with disconnecting the sway bar link. Am thinking that I can disconnect the sway bar from the top of the link (see photo) on both sides and rotate the sway bar up - perhaps zip tie it to something to keep it out of the way. My question for you (and Climbandroll): is this the connection point you removed? Or do I need to remove the bottom of the link from the frame?
Given the comment from Climbandroll I guess I'll remove it with the whole front lifted and on jack stands. But looking for advice from anyone who has done it.
2025 2026 4runner 6th gen Off road with front sway bar unbolted 20260329_181316
RunnerRocks
RedDog
Nature
2026 TRD ORP (non-hybrid)
Don't have an answer to your sway bar question.
But I wonder what that orange/pink paint splotch is for ?
My 2026 ORP (non-hybrid) also has this in the same location and only on one side..
Don't know. But its got some similarity to the spring "splotches" in the photo. Am guessing its to orient the sway bar during assembly - indicating drivers side? And on the springs it gives orientation up and down and forward. (the spring "splotches" are same on both driver and passenger side IIRC).
Just a guess.
2025 2026 4runner 6th gen Off road with front sway bar unbolted 20250816_110422
