Joestac
First, thank you moderator for making my titles always better.
Second, wanted to post this as well since I hadn't seen any info when searching.
Used a hair dryer this time since I was worried my heat gun would get too hot for the plastic around the letters. As soon as I was able to lift with the plastic pry tool, I could grab with my hand and just pull it off. Worked the rest of the leftover goo with my finger. When I got all the letters off I hit the area inside each letter with some Goo Gone, and then finished with Isopropyl alcohol to dry it all out. Did one letter at a time and pulled the tabs partially off and set the top of the letter to get it straight and then laid it down pulling the rest of the backing off. If you are used to LEGO stickers, you'll be a pro. I think, just like the front, the bronze looks so much better.
2025 2026 4runner 6th gen Rear Hatch Liftgate Letters Insert Swap - Black Reflective to --> Bronze 20251230_172356
2025 2026 4runner 6th gen Rear Hatch Liftgate Letters Insert Swap - Black Reflective to --> Bronze 20251230_172407
2025 2026 4runner 6th gen Rear Hatch Liftgate Letters Insert Swap - Black Reflective to --> Bronze 20251230_173304
2025 2026 4runner 6th gen Rear Hatch Liftgate Letters Insert Swap - Black Reflective to --> Bronze 20251230_173710
2025 2026 4runner 6th gen Rear Hatch Liftgate Letters Insert Swap - Black Reflective to --> Bronze 20251230_174513
Maximus4R
Adam
Nashville
Looks amazing! Dumb question now that you’ve seen with and without the black letters. If someone doesn’t have any of the add on letters but would want black, any reason to add them? Not sure if I’m phrasing that the best way. 🤔
Joestac
Joestac
You could have no letter indeed. The plastic in there is pretty soft, so would get scratched easy. If that matters to you.
