Hansshow Raptor Lights for 6th gen 4runner (2025+)
papadop88
2025 4Runner TRD Pro
Hansshow just dropped these raptor lights that have a custom install, clipped into the grilles, for the SR5, TRD or Limited grills.
I see these being much sleeker and custom fitting than the ones people are mounting with 3M tape or zip ties. Mounting with zip ties drives me nuts. Looks so janky.
If interested, use the link below for 20% off...
Hansshow Raptor Lights 2.0
Flexte
PENNSYLVANIA
2025 4runner TRD OR Premium
These look good. I wish that company had a video of the install instead of just instructions. StickerFab has a great video for their product. I like the snap in option of the hansshow. I just need an install video 😄
papadop88
papadop88
All the installs between manufacturers should be the same, wiring wise. With the Hansshows, the lights themselves just clip in. That would be the only difference.
Flexte
PENNSYLVANIA
Okay, thank you. I figured it just popped into an open slot but he kept going on about moving one fuse to here and another fuse to there. That part through me off and I still don't understand why he was talking about moving different fuses around. They do look like the best option and a pretty easy install as soon as I figure out the fuse situation. The ones by sticker Fab looked nice as well but 3M tape versus pop in I may go with these.
papadop88
papadop88
Ya I’m not sure why he was taking a spare fuse and all but it should be more straight forward. I think there are a few videos out there showing the install. There’s also a write up on here somewhere. If you decide to go with the Hansshows use that link to save you money.
Flexte
PENNSYLVANIA
Thanks I definitely will
Dr_Al
Alex
Rav4, Tundra
I have a set of these but don't have my Pro yet. Very few reviews, one said they didn't know how to wire them, another said they felt cheap, the 3rd said they were loose. I figure if they fit loosely I would just put a dab of black silicone on them to make them fit tightly. I'm not going to say they are the highest quality item I've ever bought but they aren't the worst.
Flexte
PENNSYLVANIA
Let us know how they fit when you get them.
papadop88
papadop88
UPDATE***
Do not buy these if you have a Pro/TH, etc. I just got mine and will be returning them to Hansshow which will take my feedback and revise the product to my needs.
1. They do not technically fit in my Pro grill. They seem loose.
2. The diamond design of the light mounts do not match the horizontal line design of the Pro Grill
3. They are matte and the Pro grill is gloss black, so they stick out like a sore thumb.
4. The light lenses themselves are clear so the LEDs inside stick out. They're noticeable.
Therefore I ordered the versions many of you ordered off Amazon that are smoke and mounted via 3M tape.
Just wanted to give everyone a heads up since I originally posted about them being an option. Not quite...
Flexte
PENNSYLVANIA
So I ended up ordering these and they were supposedly delivered yesterday. I checked around my house and my mailbox and nothing was there. Contacted them through email and all I got was a generic response please confirm this is the right address. They didn't even have a street address all they had was a city and state. And the delivery said delivered to parcel Locker
UPDATE***
Well I guess I shouldn't have jumped the gun mine just showed up today. I'm going to take the mountain see if they work on my TRD off-road premium. how was the return process? This company is hard to get a hold of
Flexte
PENNSYLVANIA
Flexte
PENNSYLVANIA
So I just installed the hansshow 2.0 lights and they fit fine. They are a little loose but they pop right in and stay in place. I installed the fuse into the empty slot behind the ignition slot. Everyone else was tapping into the ignition slot but this slot seems to work just fine at least I hope there's no issues with it. If anyone knows if that's a problem let me know.
Flexte
PENNSYLVANIA
The following is a message I sent to Hansshow regarding their Raptor lights.
Unless you feel like rigging stuff and having to do your own wiring I would suggest waiting until they fix this problem.
2025 2026 4runner 6th gen Hansshow Raptor Lights for 6th gen 4runner (2025+) {filename}
I installed these lights and they are working fine but the install is not clean and I don't know how safe the connections are. First of all the fuse jumper sits Loosely in the fuse box. There was no o-ring connector for the black ground wire so now I have a loose ground wire wrapped around a bolt. A fuse jumper connects to the red power cable but you didn't provide a connector so I had to rig it until I can strip the wires and find the proper connector. Please let me know if you can help me with any of these problems before I upload any videos I am going to start commenting in the forums but I won't upload any videos till I hear back.
2025 2026 4runner 6th gen Hansshow Raptor Lights for 6th gen 4runner (2025+) 1000045174
papadop88
papadop88
Dude, they ended up being garbage. Just return them. Fitting loosely in the grill isn’t fitting properly. And your fuse shouldn’t loose in the fuse box. I took one look at them and put them right back in the box and sent them back. They have been responsive and said they would take my feedback and redesign them.
I went with other lights and they’re perfect. Same ones many others got off Amazon. I posted the video in that thread and also in my build thread. They look and function great. Get those.
Flexte
PENNSYLVANIA
I completely install them so hopefully they will return them after I take them out. This is my first 4Runner and this is my first time doing any type of work on any vehicle. They look really good in my neighbor even said the same thing it looks like they're stock. I'm just not happy with the connections. Having a bare wire wrapped around a boat isn't something I'm happy about. Also I had to go by butt connectors I didn't install them yet I was going to work on that this weekend. I think I'll take this as a learning experience and pull them out. The only issue now is that I have a slot dremeled into the side of my fuse box. I wonder if her fuse box extender would cover that hole up? Have you seen one for the 6th gen 4Runner yet I know they have them for the 5th?. It's not that much a good deal cuz you can't see it with the fuse box lid on. Thanks for your reply like you said they just aren't designed wel. I spent a lot of money buying different connectors and trying different things to get this to work so it's a lesson learned. I don't think I'm going to go with the stickers like you have just because my OCD would drive me crazy not having them perfectly lined up perfectly. I don't even mind them being loose because they fit in uniform. My biggest issue is the connections.
