Gmoney
virginia
Installed a garmin mini 2 dash cam using the @Dongar pro adaptor. The SR5 does not have a 10pin connector. The 5-pin Dome light is the only one available to tap. Removing the rear view mirror shroud and dome light enclosure is necessary. This has been demonstrated and detailed in other threads.
First pull the smaller first piece towards you and then push down towards the front of the car and the rest of the shroud should slide off. No 10pin connector visualized. Which I have seen in installs involving the Tacoma.
2025 2026 4runner 6th gen Used Dongar Pro for install of Garmin Dash Cam Mini 2 in SR5 IMG_1494
Next pull down the dome light enclosure. Use a plastic panel removal tool to get under the front two corners to release the fasteners then push down towards the front of the car to slide the enclosure out.
2025 2026 4runner 6th gen Used Dongar Pro for install of Garmin Dash Cam Mini 2 in SR5 IMG_1495
Then to the left is the 5pin connector.
2025 2026 4runner 6th gen Used Dongar Pro for install of Garmin Dash Cam Mini 2 in SR5 IMG_1498
I attached there and then ran the power cable down through the shroud and out the side.
2025 2026 4runner 6th gen Used Dongar Pro for install of Garmin Dash Cam Mini 2 in SR5 IMG_1500
Maximus4R
Adam
Nashville
Thanks! Doing a rear view cam/mirror soon and this was helpful. I always see folks mount the dongar where they can access vs hidden. Is it dumb to hide these since they have the switch?
Rellims
Sean
ORP - Underground
Isn't the Garmin Mini 2 horizontally orientated?
jhoveln
Josh
Delaware
Awesome tutorial definitely helped me get my dashcam installed. Its definitely a bit of a pull down on the dome light unit you need to take down to tap into.
I did notice that there was a wire that presumably would be used for the factory dashcam but I couldnt use the dongar pro to tap as it was a much larger pin connector vs what came in the package.
Gmoney
virginia
I didn’t see that larger pin connector. It took me a moment to find the one I used.
Gmoney
virginia
There is just enough space to mount the dongar under the rear view mirror shroud. I placed mine outside the shroud just for ease of access. It doesn’t look as clean but I’m ok with it.
Dongar
Kevin
Norcal
2024 Tacoma TRD OR
