Method wheels ordered but they sent wrong lug nut size
lb1606
FL
I wish I knew the answer to that but the shop I initially used had a garbage wheel balance machine and they tried 3 times to get them balanced but when they couldn’t they blamed method and claimed the wheels were bad. I went to a shop with a better machine as well as better wheel guys and they had no issues. So whether or not they used the wheel hubs I don’t know. I do know the 0 offset is more aggressive than I expected
Thank you.
CrispyTacoLover
Method should be fully aware of the changes Toyota made at this point. The Tundra has been out longer than the Tacoma, and the Tacoma has been shipping well over a year.
The 2025+ 4Runner wheels have the same specs as the Tacoma and 2023+ Tundra.
Method has zero excuse.
Burgi
mike
NC
sr5
The wheels are lug centric. You don’t need hub rings but they’re nice to have. I use them because they make it easier to take the wheel on and off.
lb1606
FL
Reached out to Method Racing Wheels about this matter on May 13th of this year and this was their response,
"Thank you for your interest in Method Race Wheels.
There are no plans at this time to make the wheel with this hub bore.
Our wheels are designed and engineered to be lug centric where the wheel is centered by the lugs and not the hub.
Building a wheel in this hub bore would severely limit the vehicles that would be able to use this wheel."
CrispyTacoLover
I am not surprised. But 250,000 vehicles per year might change their mind, eventually.
SCS is building wheels for this evolution of Toyota trucks and SUV’s. So are other makers.
Method can suck it.
