Whistling noise after front air dam removal: final verdict?
Hacksaw
az
2025 4runner TRD-ORP
What's the final verdict on whether you have to plug or cover any holes (I think the holes are in the lower control arm) to get rid of the whistling noise that some have heard after removing the air dam? It doesn't seem to be resolved in other threads on this topic.
Are there only certain trim levels where you have to plug holes? Or maybe they now come plugged from the factory?
Also, what about re-installing the screws that held the air dam, after you've removed it? Is that another source for noise if you don't re-install the screws?
Anyone who has removed it, could you comment on any resulting noise (and what speed you hear it at), what trim level you have, and whether you re-installed the screws after removing it?
Same questions here but also going to check the screws holding it on based on the reports of it coming loose and damaging the paint.
Baker308
Bradley
Indiana
2025 Toyota 4Runner SR5
After removing my air dam, I never noticed any whistle, except for the turbo ;).... at any speeds
I never reinstalled the screws either.
I installed my level kit the same day so maybe I am not hearing anything because I changed the angle? Not sure
Hacksaw
az
Speaking of whistling, you know that sort of squeaky, pitch-shifting sound the parking brake makes when it engages? I pull into my garage, it engages the parking brake and makes that sound, and then a few seconds later a mocking bird in a nearby tree replicated that sound. It did it about 4 times. Kinda funny.
Baker308
Bradley
Indiana
Speaking of whistling, you know that sort of squeaky, pitch-shifting sound the parking brake makes when it engages? I pull into my garage, it engages the parking brake and makes that sound, and then a few seconds later mocking bird in a nearby tree replicated that sound. It did it about 4 times. Kinda funny.
I am 1500 miles into this vehicle and have yet to have any brake squeak... but I have read about others having that same issue
LLL1990
Toyota Camry and Ford F-150
I thought the correct procedure was to reinstall the screws after removing the air dam
Baker308
Bradley
Indiana
Preference I guess! :)
The screw holes are only in place to mount the air dam... In my opinion, there is no point.
Saved them in a baggy taped to my air dam
Hacksaw
az
It might not be the same for the 4runner but in the tacoma air dam removal videos I just watched, either 4 or 6 of the 9 screws also hold other plastic things besides the air dam.
spwaca
2025 Toyota 4runner TRD ORP
I took off my air dam and replaced the screws. I have a TRD ORP. I don’t notice any difference in noises while driving, and I don’t hear a whistle.
AZGOLD
AH
Prescott
2025 ORP 4runner
Regarding wind noise after air damn removal. People are probably hearing the very slight turbo whistle at cruising speeds
this is an old issue from the other new gens models with air dams (ie early 2016 taco's had this issue)
sometimes when you removed the air dam, it would open up weird air pathing under the vehicle to where open holes in the frame would start to whistle.
you have would have to plug them up until you find the one causing the whistle.
i think there was even a tsb issued for this on the 2016 taco's
timelapse
ATL
2025 ORP
I’ve got 1500 miles with the air dam off and lots of highway miles without any whistling sounds.
If you don’t remove the old clips when removing, you’ll get some rattling. I initially forgot to remove two of them and quickly realized.
On an unrelated issue, driving gravel forest service roads on the ORP has been a less than ideal experience for us. We drive them frequently to access mountain bike trailheads and the vehicle has so much noise and frame vibration on gravel roads. Tire pressure at 34… not going to air down for forest service roads. I’ve also noticed that gravel loves to kick up and make annoying pinging sounds on the 6th gen.
Our 5th gen would plow the same roads with far less noise and overall clunkiness.
Ironhead
Charleston, WV
2025 Toyota Tacoma Limited, 2024 Lexus RX 350H
Here is a post from Tacoma World on this issue so I would assume the same is on the 4 Runner. There are 4 holes on the lower control arm that needs plugged. You can buy the plugs from Toyota or from Amazon. Some models come with them and some dont. Here is a picture of the control arm and a link to the thread. I had the noise on mine after removing the air dam and the plugs fixed it.
Noise after removing air dam | Page 4 | Tacoma World
2025 2026 4runner 6th gen Whistling noise after front air dam removal: final verdict? plugs
