Premium Headlights part number
jofe
Has anyone figured out the part number for the headlights that can be found on the Trailhunter and TRD Pro by any chance?
going to look kinda weird since they have a trailhunter lettering on the lights and you not actually having a trailhunter.
but its a minor issue if you dont have ocd :)
TrailHunter LED Headlights: You get the illuminated TrailHunter icon stamped on the passenger and the "TrailHunter" text stamped on the driver's side.
jofe
Fair point @Nodak I didn’t think about the text on them. I’m more interested in the lights themselves. Just think they look great. Do those “premium” headlights have lettering on the other models too? Platinum or Limited for instance?
@jofe i think only the pro's and trailhunter's do.
LLL1990
Toyota Camry and Ford F-150
The premium headlights are on the Limited, Platinum, Pro and Trailhunter.
jofe
As far as I can see in videos the premium headlights on the limited just says “4runner” on each side. So that would be the better choice imo.
i guess i should have clarified, only the pro's and trailhunter have specific lettering to those specific models.
jofe
I found these part numbers. It’s a bit confusing because their pages all have two images, one with the non-“premium” headlight, and one with the “premium headlight. These came up when selecting the 2025 4runner TRD Pro within the Toyota parts website
Almost $2,800 for these headlights before taxes though. Yikes.
2025 2026 4runner 6th gen Premium Headlights part number IMG_1394
2025 2026 4runner 6th gen Premium Headlights part number IMG_1395
mintxo
AZ
sr5
Bump, did we figure out which one is which?
willcasp
William
Bothell
Are the Limted headlights plug and play for the TRD Off Road Premium?
the higher cost one's i think are the self leveling version ???
the others are the manual leveling ones tied into the dash switch with +0 thru +5 settings ???
JayTech
Jay
They are almost all plug and play from what I can see. Looking at the parts diagrams for the connectors for the headlamps they all use the same connectors on the back except base models if they do not have the levelling motor. But the other 2 connectors are still the same so they should still function fine but you won't be able to manually adjust the levelling of the light.
Limited part numbers should be LH: 81070-35661, RH: 81140-35661
TRD Pro part numbers should be LH: 81070-35681, RH: 81140-35681
Trailhunter part numbers should be LH: 81070-35671, RH: 81140-35671
yungsocks
Central Valley, CA
2025 ORP - Everest
How were you able to decipher the part numbers per headlight?
A user on the 6th Gen 4Runner Facebook group is actually doing this upgrade, and ordered 81140-35680 and 81070-35680 which are confirmed to be TRD Pro with the stamps on the headlights. Haven't heard the verdict yet, but I believe they are going to install them this weekend on their Off Road Premium.
I am leaning towards the limited ones since those don't have a trim stamp on them.
if i remember correctly the limited and platinum headlights only have "4RUNNER" on them. the lower trims have no headlight markings. TH and PRO have unique markings.
