Where's A-Trac?
Kroney70
Cleveland, Ohio
2016 Subaru Outback 3.6 Limited
I read in another thread that A-Trac is now automatic in the 6G. If this is true, what turns it on? 4Lo? Crawl mode? MTS? Specifically on the TRD Pro as that's what I'm planning on purchasing. Been trying to find a more detailed explanation and can't find a detailed answer anywhere. Thanks for your help.
4WheelBugout
Subaru
I don't know where it is, but I did hear that for 6 gen it is now active while in 4HI - previously it was only in 4LO, and maybe 2HI.
kzrman
Maine
2025 Trailhunter
A -Trac stands for automatic traction. Maybe try page 431 in the Owners Manual. It is found under the Owners section on the Toyota website. I hope this helps.
https://www.toyota.com/owners/warranty-owners-manuals/
On page 431 I see "TRAC". Is this the same as A-Trac? From what I can tell from the manual "TRAC" automatically comes on when it senses wheel slip and the only choice the user has is to temporarily turn it off. Am I missing something?
LLL1990
Toyota Camry and Ford F-150
Toyota seems to have programmed it into the traction control system in all the 4x4 models. From what I understand, it's integrated into the different MTS modes or when it's in 4Lo. In the full time 4x4 system it's active in 4Lo. I can't say that I'm 100% certain about this since Toyota doesn't refer to A-TRAC anymore, including in the Land Cruiser, GX and LX.
Kroney70
Cleveland, Ohio
So when you say they programmed it into the traction control system/integrated into the MTS modes, that means, for example, if I’m in Rock mode, it will come on when needed?
I’m surprised the YouTube reviewers (and it seems like NONE of them) have even brought it up during their reviews of the new 4Runner. That surprises me because they always point out and rave about the A-Trac system in their older reviews when they are filming their rock crawling.
LLL1990
Yes. Instead of having to press a button they took the Land Rover route and has it always active in off road modes or in 4LO. Its intervention is different depending on the MTS mode you're in, similar to how Land Rover has been doing their Terrain Response system for many years now. This makes much more sense than having to press a button to turn it on.
Kroney70
Cleveland, Ohio
Much appreciated!
i thought a-trac was different than trac or am i thinking VSC since thats the flashing icon i get on the dash when i get wheel slip on ice in my limited
kzrman
Maine
2025 Trailhunter
You're probably thinking about VSC or Vehicle Stability Control. VSC senses when the vehicle is slipping and does things like decreasing the throttle in order to try and keep the vehicle under control.
kzrman
Maine
2025 Trailhunter
Thank you for the explanation. I wish that the owners manual went into this.
jayT
john
Louisiana
You are correct. I was examining the specification sheet of my 2025 4R SR5 PT4WD and ATRAC(ACTIVE TRACTION CONTROL) is automatic in 4WD-4LO. Also, it's kind of weird b/c you will not get a light on dash board telling you ATRAC is on. You only know that it is working when your tire(s) are slipping and feel the braking system PULSATING. Another kind of stupid thing, there is not one SINGLE reference to ATRAC in the OWNERS MANUAL about ATRAC but rather only TRAC...hope this helps..
jayT
john
Louisiana
Thanks!
