- Thread starter
- #1
Official 2025+ 4Runner 6th Gen Specs
Download the full official specs sheet / product info PDF (text searchable)
: https://www.4runner6g.com/forum/attachments/2025-4runner-specs-product-info-pdf.5259/
Trim Levels / Models (click on each for specs, features, options, accessories):
Colors:
Engines
Drivetrain / Transmission
Vehicle Weight
Exterior Dimensions
Wheels, Tires, Bolt Pattern, Lug Nut Size, Hub Bore:
Suspension
Ground Clearance, Approach Angle, Departure Angle, Breakover Angle
Safety Features
Off-Road Tech / Features
Production
Pricing
2025 Trim Levels Compared: features, equipment, options
Text searchable PDF version of the chart (PDF download): 2025 toyota 4runner trims comparison - features options exterior chart.pdf
2026 4Runner vs. 2025 LAND CRUISER
- SR5 (i-Force)
- TRD Sport (i-Force)
- TRD Sport Premium (i- Force)
- TRD Off-Road (i-Force / i-Force Max Hybrid)
- TRD Off-Road Premium (i-Force / i-Force Max Hybrid)
- Limited (i-Force / i-Force Max Hybrid)
- Platinum (i-Force Max Hybrid)
- TRD Pro (i-Force Max Hybrid)
- Trailhunter (i-Force Max Hybrid)
Colors:
- Black
- Cutting Edge
- Everest
- Heritage Blue
- Ice Cap
- Mudbath
- Supersonic Red
- Underground
- Wind Chill Pearl
Engines
- i-FORCE (Gas Option)
- Type: 2.4L 4-cylinder Turbocharged, DOHC
- Fuel System: D-4ST Fuel Injection
- Displacement: 2,393 cc
- Horsepower: 278 hp @ 6000 rpm
- Torque: 317 lb-ft @ 1700 rpm
- Fuel Economy:
- 2WD (SR5, Sport, Sport Premium): 20 MPG city / 26 MPG highway / 22 MPG combined
- 4WD (SR5, Sport, Limited, etc.): 19 MPG city / 25 MPG highway / 21 MPG combined
- Engine Oil Capacity: 5.9 quarts (with filter)
- Fuel Tank Capacity / Gas Tank Capacity: 19 gallons
- Recommended Fuel Type: Regular Fuel / Gas
- i-FORCE MAX (Hybrid Option)
- Type: 2.4L 4-cylinder Hybrid Turbocharged, DOHC
- Horsepower: 326 hp @ 6000 rpm
- Torque: 465 lb-ft @ 1700 rpm
- Fuel Economy:
- 4WD (Off-Road, Limited, TRD Pro, Trailhunter): 23 MPG city / 24 MPG highway / 23 MPG combined
- Drivetrains:
- 4x2 (Rear-wheel drive RWD)
- 4x4 (Part-time or Full-time four-wheel drive 4WD)
- Transmission Type:
- 8-speed Automatic Transmission with following gear ratios:
- 1st gear: 4.41
- 2nd gear: 2.80
- 3rd gear: 1.95
- 4th gear: 1.51
- 5th gear: 1.27
- 6th gear: 1.00
- 7th gear: 0.79
- 8th gear: 0.65
- Reverse: 3.64
- Transfer Case (4x4 models):
- High/low ratio of 1.00:1 / 2.57:1
- Final Drive Ratio:
- 3.583
Vehicle Weight
- Curb Weight (lbs):
- Gas Engine (i-Force)
- 2WD SR5: 4,455 lbs
- 2WD TRD Sport: 4,610 lbs
- 2WD Limited: 4,730 lbs
- 4WD SR5: 4,685 lbs
- 4WD TRD Sport: 4,850 lbs
- 4WD TRD Off-Road: 4,850 lbs
- 4WD Limited: 4,970 lbs
- Hybrid Engine (i-Force Max)
- Hybrid TRD Off-Road: 5,225 lbs
- Hybrid Limited: 5,370 lbs
- Hybrid Platinum: 5,390 lbs
- Hybrid TRD Pro: 5,455 lbs
- Hybrid Trailhunter: 5,500 lbs
- Gross Vehicle Weight Rating (GVWR) (lbs):
- 2WD SR5: 6,005 lbs
- 2WD TRD Sport: 6,020 lbs
- 2WD Limited: 6,130 lbs
- 4WD SR5: 6,075 lbs
- 4WD TRD Sport: 6,395 lbs
- 4WD Off-Road: 6,240 lbs
- 4WD Limited: 6,395 lbs
- Hybrid TRD Off-Road: 6,505 lbs
- Hybrid Limited: 6,505 lbs
- Hybrid Platinum: 6,505 lbs
- Hybrid TRD Pro: 6,505 lbs
- Hybrid Trailhunter: 6,505 lbs
Exterior Dimensions
- Wheelbase: 112.2 inches
- Length: 194.9 inches
- Width: 77.9 inches (79.9 inches for TRD Pro / Trailhunter)
- Height:
- SR5: 72.6 inches
- Sport, Limited, Platinum: 73.1 inches
- Off-Road / Off-Road Premium: 73.6 inches
- TRD Pro / Trailhunter: 74 inches (75.5 in w/ roof rack)
- Seating Capacity: 5 (7 seats available on i-FORCE SR5 and Limited trims)
- Interior Space:
- Shoulder Room (Front/Rear): 58.0 in / 57.8 in
- Hip Room (Front/Rear): 55.2 in / 56.1 in
- Headroom (Front/Rear): TBA
- Legaroom (Front/Rear): TBA
- Cargo Capacity: N/A (varies by configuration)
17" inch dark gray metallic alloy wheels
TRD Sport (Premium)
31.5" Yokohama Geolandar A/T G015 Tires (265/55R20)
TRD Off-Road (Premium)
18" inch machine finished alloy wheels
32.6" Michelin All-Terrain tires (265/70R18)
20" inch black alloy wheels
18" inch flat bronze finished alloy wheels
18" inch flat black finished alloy wheels
Bolt Pattern: 6-139.7
Lug Nut Size: 14x1.5
Hub Bore: 95.1
Suspension
- Front Suspension: Independent double-wishbone with stabilizer bar and twin-tube shock absorbers
- Rear Suspension: Multi-link with coil springs and outboard-mounted twin-tube shock absorbers
- Steering:
- Electronic Power Steering (EPS)
- 3.25 turns lock-to-lock
- Turning Radius: 19.7 ft
SR5 | Sport, Limited, Platinum | Off-Road | TRD Pro / Trailhutner | |
| Approach Angle | 18 degrees | 18 degrees | 19 degrees | 33 degrees |
| Departure Angle | 22 degrees | 22 degrees | 24 degrees | 24 degrees |
| Breakover Angle | 23 degrees | 24 degrees | 24 degrees | 24 degrees |
| Ground Clearance | 8.1 inches | 8.8 inches | 9.1 inches | 10.1 inches |
Safety Features
- Toyota Safety Sense 3.0 is standard on all 2025 models and includes:
- Pre-Collision System with Pedestrian Detection
- Lane Departure Alert with Steering Assist
- Full-Speed Range Dynamic Radar Cruise Control
- Lane Tracing Assist
- Road Sign Assist
- Automatic High Beams
- Proactive Driving Assist
- Front stabilizer bar disconnect
- 2wd, part-time 4wd, or full time 4wd
- Locking rear diff standard on TRD Off-Road, TRD Pro or TrailHunter.
- MTS (Multi-Terrain Select)
- Crawl Control
- Approach Angle: 32 Degrees
- Departure Angle: 24 Degrees
- TRD Pro Light Bar
- Rigid Fog Lights
Production
- December 2024 start of production for non-hybrid models
- February 2025 start of production for hybrid models
Pricing
- See all MSRP base prices & options pricing at: 4runner6g.com/forum/threads/2025-4runner-price-release-msrp-options-pricing-for-all-trim-levels-gas-hybrid-models-6th-gen.1952/
| Specs | 2025 Toyota 4Runner I-Force Max | 2024 Toyota Land Cruiser |
| Engine | Turbocharged 2.4-Liter Four-Cylinder Hybrid | Turbocharged 2.4-Liter Four-Cylinder Hybrid |
| Transmission | 8-Speed Automatic | 8-Speed Automatic |
| Drivetrain | Part-Time or Full-Time 4WD With Two-Speed Transfer Case | Part-Time or Full-Time 4WD With Two-Speed Transfer Case |
| Power | 326 HP / 465 lb-ft | 326 HP / 465 lb-ft |
| Towing | 6,000 Pounds | 6,000 Pounds |
| Wheelbase | 112.2 Inches | 112.2 Inches |
| Overall Length | 194.9 Inches | 193.8 Inches |
| Overall Width | 77.8 Inches | 77.9 Inches |
| Overall Height | 70.8 Inches | 76.1 Inches |
| Ground Clearance | 9.2 Inches | 8.0 Inches |
| Approach Angle | 32 | 31 |
| Departure Angle | 24 | 22 |
| Breakover Angle | TBA | 25 |
| Fuel Capacity | 19 gallons | 17.9 gallons |
