Cledope
Tim
Northeast TN
Created my first ever video and YouTube post of me installing the CarTrimHome c12 head unit. More content to come. I will be available for any questions tomorrow evening. If you're interested check it out!
Thanks
Odysseas
Odysseas
BC
Hi very nice video . I installed mine 3 days ago. I saw that you have only 2 wires that you did not plug anywhere. This is weird because I have 4 of them see attached pictures. The white big one is the one that you said for the white and red RCA cables but they have not sent me anything for this cable. I assume that its for the audio but I am not sure for which speakers is this wires for. I think that all my speakers are working .
I think we have 6 speakers in the sr5 .
The other 3 I assume that they are for the GPS , Sirius and I don't know the 3rd one ( maybe microphone ???)
2025 2026 4runner 6th gen Installed the Cartrimhome C12 head unit 14.6" display (aftermarket)  into my 2025 SR5 Screenshot_20260726_003313_Gallery
Cledope
Cledope
Tim
Northeast TN
Hi very nice video . I installed mine 3 days ago. I saw that you have only 2 wires that you did not plug anywhere. This is weird because I have 4 of them see attached pictures. The white big one is the one that you said for the white and red RCA cables vut they have not sent me anything for this cable. I assume that its for the audio but I am not sure for which speakers they are asking all my speakers working. I think we have 6 speakers in the sr5 .
The other 3 I assume that they are gor the GPS , Sirius and i don't know the 3rd one ( maybe microphone ???)
Hey,
Thank you for the compliment.
I was told by car trim home that you may not need the rca cable that attaches to the white plug pictured. Yes, there are 6 speakers in the sr5. You can use the audio options in the unit to balance to each speaker to make sure you have sound just to double check.
if you could give me some time I will pull my unit and double check which wire you have left unconnected, did you connect your head units usbc?
Odysseas
Odysseas
BC
Hey,
For sure man take your time .
They said the same think to me that we dont need to connect the RCA cables because it could cause problems with the speakers but it feels weird not to connect a factory cable. I have connected everything except of the 4 wires .
I did transfered and the the Factory USB C already .
Cledope
Cledope
Tim
Northeast TN
Yup, if you didn’t connect the rca cables, audio should still work fine and confirm those 3 would not be used. I took it apart last night while filming part of my next video, unplugged the rca cables and still was getting volume. I did not go much further than testing the audio which worked fine. The white bigger plug is what the audio cables would have ran from. So.. you are correct in your current setup.
Cledope
Cledope
Tim
Northeast TN
Ok, I see you have 4 connectors there. I only have one of the black connectors left. I could not locate an additional one. Cartrimhome is very responsive to any emails though so far in my experience.
Odysseas
Odysseas
BC
Hmmmm interesting .
This is the 4th cable . Do you remeber connecting it this cable anywhere ?
I have already asked CTH if they know what those wires are but they don't know exactly.
2025 2026 4runner 6th gen Installed the Cartrimhome C12 head unit 14.6" display (aftermarket)  into my 2025 SR5 Screenshot_20260730_225729_Photo Editor
From your video its the wires that you are pulling
2025 2026 4runner 6th gen Installed the Cartrimhome C12 head unit 14.6" display (aftermarket)  into my 2025 SR5 Screenshot_20260730_232605_Chrom
Cledope
Cledope
Tim
Northeast TN
Hmmmm interesting .
That is not attached to anything.
2025 2026 4runner 6th gen Installed the Cartrimhome C12 head unit 14.6" display (aftermarket)  into my 2025 SR5 imag
Cledope
Cledope
Tim
Northeast TN
Yes ok I am thinking that this maybe is the digital microphones but I am not sure
That makes sense because the microphone built into this unit is no good. I plan on buying a mic that plugs into a mic input on the back. You should look into too if you it’s on the same cable harness that I plugged the Nintendo into.
Odysseas
Odysseas
BC
I have think about external microphone but I am not sure if I need it yet. Have you adjusted the microphone gain in sound settings to see if it will make a bit of difference? . I have put it on 6 and it seems that it works better .
Cledope
Cledope
Tim
Northeast TN
Yeah it does work better with the gain up. I communicate with a large elderly population for my job and it does not quite get the job done for me so that could be the difference. I’m looking at a aftermarket Sony mic that apparently has very good sound quality and I was thinking of running it to the top of the head unit on the drivers side.
bigbruse
robbie
va
2025 4runner
Anybody install the volume control knob yet to this unit?
