TRDORP Non Hybrid High Beam trigger wire???
Bryan
Northern California
2026 4Runner Off Road Premium
I did get a working solution just a couple nights ago but have been giving it a few days before posting it. I’m out of town on the road but will share what I’ve done soon. Be warned, it isn’t a cheap solution but it is a stupid simple one that took less than 10 minutes.
At this point I would gladly pay money for a stupid simple 10 minute solution. A lot of money.
Bryan
Northern California
all I got is
the connector in the dash... z22.. (first pic) for the turn/high beam stalk
(first red line from the left side of pic)
and the pin that is activated (1) in that connector (second pic)
when the high beam switch is on (pushed forward)
Just thought I would let everyone know, trying to tap into this wire for either a +12V signal or ground signal to trigger a relay might be doable, but be forewarned....
The diagram is misleading. The connectors are actually located far up in the dash behind the main instrument display. Getting reasonable access is going to involve major disassembly of the dash. I'm going to keep it in mind as a LAST resort, while seeking a better way.
Thanks again to 127.0.0.1 though. It should be possible, but I would almost rather pull an engine than tear apart the dash in a brand new car.
Bryan
Northern California
Just to follow-up on this....
I gave up trying to decipher Toyota's wiring setup, and bought a Canny. Implementing it wasn't necessarily simple or easy, because the documentation on the device is minimal and there is nothing whatsoever related to the 4Runner specifically.
I understand CAN basics, but the 4Runner has multiple CAN networks, and the Canny will not work unless it is installed on the correct one. After several failed attempts, I found that the "correct" CAN network comes off the "Main Body ECU" located under/behind the glove compartment. There are three or four connectors plugged into the front of the ECU. One of the smaller connectors has a white wire and a pink wire coming out of positions one and two of the connector. These two wires are taped together, just the two of them, something that Toyota seems to do with all their CAN wires. The white wire is CAN low and the pink one is CAN high. This sounds like a wild goose chase, but if you are looking on the front of the Main Body ECU (Toyota speak) the wires are fairly obvious. These are the wires you need to tap into for the Canny to work.
Whether there are easier locations to access these wires, I cannot really say, but I doubt it.
I meant to include diagrams from the TIS, but my two day subscription expired. Learning to discern any useful information from the TIS was a feat for me in itself, but that's another story.
Anyway, the Canny is wired in now, and does exactly what it is supposed to....trips my relays when I switch on the high beams.
Honestly, if I had known what was going to be involved getting this to work, I might have contented myself with the stock headlights.
Twisted
Twisted
5th Gen TRD -> 6th Gen TRDORP
How much fun was it to get to the unit? I have a CANM8 that I was unable to get to work with the contactless reader at the headlight. I would receive a signal but couldn't decipher it or whatever. I was hoping it would be similar to the Tundra and some of those folks have had success tapping into the wires at the light. Many of them have also tapped into some module behind their glove box as well.
Twisted
Twisted
I wanted to make a short video by now but life has been hectic so I'll simply share my solution until I can make the video. I took a bit of a risk and bought the XBB unit. It is $400 with no returns but fortunately it works exactly as I had hoped.
https://strandsamerica.com/products...XE4XacZjv-bEh5VswRvpTuT4ijHB95hHhmGWNYbDsnRn0
Plug a dongle into the OBD port, connect to it with your phone to set it up, use the Tundra recipe, wire a positive and ground to the relay unit, trigger wire to my BantamX, select high beam for trigger one in the app, and all works as it should. Was about a 5 minute install made easy because I was mostly wired already. I installed the relay under the hood at my SPOD unit but will probably move it under the dash just to keep it a little safer.
You only need your phone and app to set it up. After that the relay and dongle talk directly to each other. I've had it installed almost a week and 3 tanks of fuel. Has worked every time. (I've been randomly trying it to ensure it works when I need/want it.)
