Black wheel locks and lugnuts
jbol74
Jerrod
2025 4runner trd off road
Hi, I have a 2026 TRD ORP with the upgraded Black TRD accessory wheels. Does anyone know the Toyota part numbers to matching satin black wheel locks and lugnuts? I called Toyota and they said only black chrome is available for the 2026. Any help is appreciated
horbit
DFW
PT076-0C200-02 : Flat black lug nuts
PT276-34231-02 : Black wheel locks
jbol74
Jerrod
Perfect Thanks! I thought these were the correct part number but when I enter them in on the Toyota website it say “ part does not fit your vehicle” I think it must be a glitch
horbit
DFW
Its not listed as a compatible part, but they fit perfectly. Just don't use an impact wrench on them, the coating is pretty thin.
jbol74
Jerrod
Dang
JD013
New Jersey
2026 4runner
Advanced wheel locks makes some really nice wheel locks as well. They've been my go-to on my last few vehicles.
bowhun2r
Scott
Pittsburgh
26 4R Limited : 26 Volvo XC60 (wife's)
One item to note regarding the Toyota OEM black lugs, they are 22mm (as are some aftermarket ones). The factory chrome lugs are 21mm... which is also the factory spare tire kit size. So if you do go with these, make sure to pick up a 22mm socket/breaker bar.
I was going with the Toyota ones, but instead went with these (also 22mm): https://www.extremeterrain.com/4run...r-oem-wheels-m14x15-set-of-24-w566014dmb.html
2025 2026 4runner 6th gen Black wheel locks and lugnuts IMG_2580 (1)
BLM... Black Lugs Matter
2025 2026 4runner 6th gen Black wheel locks and lugnuts IMG_2635
22mm socket
https://a.co/d/09YghnD1
Breaker bar
https://a.co/d/00b06ne7
jbol74
Jerrod
22mm socket
Breaker bar
Good info!! Thank you !
