Exterior Tailgate Left Light Will Not Turn Off
mcd_ovrlnd
SE PA
2025 4Runner TRD PRO
Anyone experience this? Just started tonight. And it happened after I installed a Meso Customs white/red dome light. I read that the light at issue is tied to the dome light in some way. The Meso light wasn’t turning off at first. Then finally started working but then the exterior tailgate light wouldn’t turn off. I swapped the OEM done light back in but issue persists.
bird
SF Bay Area
25 TRD ORP
Pretty sure it is a switch around the auxillary buttons, against the dash by your left knee.
mfoga
r4unner
have you tired pulling battery negative to see if that will reset something? Did you disconnect battery to install?
mcd_ovrlnd
mcd_ovrlnd
SE PA
did not disconnect battery on install. Have never done that for an interior light upgrade. I’ll try unplugging for reset.
mcd_ovrlnd
mcd_ovrlnd
SE PA
After 40 mins it just magically turned off. Given it happened immediately after I did the Meso Customs dome light swap, I figure the two had to be related. Head scratcher.
