Van Solo
Van Solo
Van
Calgary / Canada
Do you like the ride and is it better than the stock Bilstiens
Do the bump stops do anything special?
TIMBREN Off Road Bump Stops sit lower and will soften the transitions and offer smoother ride quality when they make contact!
The ride is truly night and day!
on pavement it absorbs so much more than the stock let alone off road!
Striker53
Sean Ruth
Prince George
2025 off road Premium
Thanks. I emailed them but they wouldn’t really say if the ride would be better than the stock Bilsteins. Got a little frustrated with them. Just looking for a plusher ride on the road and fireroads. Nothing crazy
Van Solo
Van Solo
Van
Calgary / Canada
This will then blow you away
Rodo94
San Francisco, CA, USA
4Runner 2026 Platinum
I watched a bunch of "blind test" videos, reviews are always neutral on pavement like "all shocks are the same"
I need to find someone in the Bay Area having aftermarket shocks
Van Solo
Van Solo
Van
Calgary / Canada
I myself have noticed they are not as hard! Bumps and uneven pavement is I’m my opinion way less harsh!
I am enjoying them very much so and everyone can decide what they do with their Rig!?
porkyfly
Mid atlantic
2025 4runner TRD Offroad
are the OME control arms required to use the MT64's? Do the shocks not fit with the factory control arms?
Van Solo
Van Solo
Van
Calgary / Canada
Daronc
Daron
Santa Clarita, CA
Alright, since we all had so many questions that went unanswered I decided to get to those myself.
Old Man Emu kit number 2135K by ARB
Included parts are as follows as seen in the image below:
  • FK134 Brake Line Spacer Kit 1
  • FK137 Sway Bar Spacer Kit Rear 1
  • MT64601052 MT64 Shock Absorbers Rear 2
  • 3344 Coil Springs Rear 2
  • MT64996013 MT64 Coilover Struts Front 2
  • UCA0037 Upper Control Arms 2 (with ABS spacer brackets)
Now this 2135K kit comes preset at 3" Front and 2" Rear lift
For the installation I opted to go with Kal Tire Shawnessy in Calgary, Alberta for a few reasons, the first being I knew a few folks at the location and felt comfortable with all of it.
Kiran is one of the assistant Managers and Darcy is a Technician with a lot of passion for work like this..
So lets us begin with the installation.
And the original parts video with Old Man Emu MT64 Kit 2135K
Before:
After:
Remaining Parts:
After passenger side on the ground Axel angle.
Total time 4 Hours labour + Alignment. Great work Darcy!
(Remember this vehicle is coated in Krown Rust Proofing here in Calgary, Alberta so everything remains rust free and protected and easy to work on)
Now I have driven a bit on these before we head back to the shop to lift it up and check those questions off.
Ride Quality: Better than stock in many ways and we are running 285/70R17 Wrapped in Open Country AT3 C-Ply set at 37 PSI.
1. Sitting higher feels better
2. Speed Bumps, are much smoother
3. Driving off curbs, So much smoother
4. Calgary Roads, in general smoother less Stiff
5. Turns, No issue at all (Body Roll)
6. Speed, No difference at all
Axel Angles are looking good and zero vibrations 0-125Km (Just have not exceeded 125Km yet)
Back to the shop in the AM to get those final images and references some asked me about.
Old Man Emu MT64 3"/2"
Blackhorn Off Road Wheels 17x8.5 6.1397 ET25
Toyo Open Country AT3 285/70R17 C-Ply
Updated with off-road testing trip review:
A day out testing the Old Man Emu & TIMBREN Offroad Bumpstops with my Daughter, and let me tell you it was fantastic!
We enjoyed a variety of trail conditions in higher and lower altitudes such as:
Pavement
Gravel
Soft Muddy
Icy & Hard
Deep Snow
our 4Runner took it all in and our Suspicion upgrade from Old Man Emu & Timbren made is a comfortable day exploring the out doors.
We had taken this same route with our stock suspension and the difference was night and day.
All I can say is I am very pleased with this upgraded package and now know we made the right choice for our 4Runner.
We will be doing more trails this summer and always more upgrades so stay
tuned and follow our build page below in the signature area.
2025 2026 4runner 6th gen OME MT64 Old Man Emu Suspension w/ UCA (Part #2135K) + Timbren Active Off-Road Bumpstops -- Installation & Review...by Van Solo {filename}
Great write-up and your 4Runner, nicely done! Would you be able to measure from the center wheel hub to the bottom of the fender flare as I would like to see what was the actual height you obtained
Daronc
Daron
Santa Clarita, CA
Before:
After:
Remaining Parts:
Pavement
Gravel
Soft Muddy
Icy & Hard
Deep Snow
Van Solo
Van Solo
Van
Calgary / Canada
Did OME provide alignment specs?
Full factory Alignment specs are reachable with the 2135K kit!
Timbren Bump Stops are 1" from Axle and offer smooth yet firm Support without the bang!
