Suspension height difference: TRD Pro vs. TRD Off-Road?
DangItsDen
Hayden
Does anyone know exactly how much lift the pro has over the OR? Google says it's 1" higher on the pro, but it seems like its more than that. Also curious what the difference in the rear is.
If not, can anyone with a stock pro measure from tire to fender flare please? Thanks in advance!
kekecarioca
_CAC_
I have a TH and haven't compared side by side w/ TRDOR, but seeing them on the street seems like a very minimal difference to me.
I think Pro and TH have same spec's on lift.
4.75" Front and 5.5" rear : bottom of fender flares lip to top of tire. Note: Flares are not same between TRDOR & TH.
DangItsDen
DangItsDen
Hayden
You legend! Thanks for the info
RAB
Labrador
Nissan , Chev,Jeep
Would the UCA geometry be the same on all these models ?
Tarekith
Upper Left US
4Runner ORP & ‘22 Tacoma OR
I just measured my ORP, and it's about 5" in the rear and 3.75" in the front FWIW.
DangItsDen
DangItsDen
Hayden
For reference: my ORP on pro wheels with 265/70/18 at3s + 1.25” peak front lift.
Front: 4.4”
Rear: 5.6”
And mine on TRD ORP:
Before: stock tires & wheels (18x7.5, +55) & suspension: Front: ~3.8"; Rear; Rear: ~5.3"
After: Toyo A/T III 285/70R18, TRD PRO wheels (18x8.5, +20), Peak 1.25" level: Front: 3.5"; Rear: 4.5"
I guess the .8" difference in the rear is close enough to half the increase in tire radius (.55"), but I can't reconcile the front difference. I'd expect it to be lift (1.25")-radius delta(.55")= ~-.7" but only ~-.3". Maybe a difference in scrub angle on the lower offset wheels is a factor?.
I'm compiling data on differences in ground clearance from key points - very incomplete but ranges from 2.3" increase below air dam in front to 1.6" on the frame cross bar to 1.4" on the rear diff. Lift and bigger tires are doing their job in that area.
TRD ORLIMITED/PLATTRD PRO / TH
Exterior (in.)
Overall length194.9194.9194.9
Overall width (without mirrors)787879.9
Overall height (does not include roof rails or roof rack)73.673.274
Wheelbase112.2112.2112.2
Track width (front/rear)66.0 / 66.165.6 / 65.768.8 / 68.8
Interior (in.)
Head room (front/rear)39.7 / 37.838.3 / 37.838.3 / 37.8
Shoulder room (front/rear)58.0 / 57.858.0 / 57.858.0 / 57.8
Hip room (front/rear)55.2 / 56.155.2 / 56.155.2 / 56.1
Leg room (front/rear)41.8 / 34.841.8 / 34.841.8 / 34.8
