Raptor lights for the Trailhunter Heritage grill?
cama0303
MN
2025 Trailhunter
Those look really good!
mmoore031908
Max
2025 4Runner TRD Pro Ice Cap
Driving Lights
Hi Beams
Good call on these lights. They are awesome. Bought some and took about 30 minutes to install. They are less than half the price of the Hansshow Lights and seem to be better quality wiring in my opinion.
Griffin27
So Cal
Installed these on my Pro Grille, no drilling. Don't even notice them until you turn them on. Look great.
I used one of the pigtails for the aux switches to make the hookup.
https://www.amazon.com/dp/B0DLL9BQ17?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
These are the easiest to install and they look great. Mine are hooked up directly to a spare fuse in the fuse box. They turn on when the car turns on, off when the car is off.
Someone now needs to figure out how to keep the OEM fog lights ON when the headlights are off :)
2025 2026 4runner 6th gen Raptor lights for the Trailhunter Heritage grill? IMggggG_3402
2025 2026 4runner 6th gen Raptor lights for the Trailhunter Heritage grill? IMGdddd3401
papadop88
***UPDATE***
Do not buy these if you have a Pro/TH, etc. I just got mine and will be returning them to Hansshow which will take my feedback and revise the product to my needs.
1. They do not technically fit in my Pro grill. They seem loose.
2. The diamond design of the light mounts do not match the horizontal line design of the Pro Grill
3. They are matte and the Pro grill is gloss black, so they stick out like a sore thumb.
4. The light lenses themselves are clear so the LEDs inside stick out. They're noticeable.
Therefore I ordered the versions many of you ordered off Amazon that are smoke and mounted via 3M tape.
Just wanted to give everyone a heads up since I originally posted about them being an option. Not quite...
stealurkill
Bryant
Louisiana
Two questions. Where did you find the white ones and what fuse are you referring to?
kayleighk116
Kayleigh
Connecticut
2025 4 Runner Trailhunter
MartyMcFly
Did you use an auxillary switch or tie them into the
Did you use on of the four auxiliary switches on the Trailhunter or did you tap into the fuse box? I bought these - https://www.amazon.com/dp/B0FS6LPKXW?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 - and am not electrically inclined. If you used the auxiliary switch, how do you do it?
I used Aux 4 for mine. I connected the ground to the white/black wire of the pigtail and the power to the green wire.
The hardest part is getting the cap off where you plug the pigtail in. I popped the plastic plate off from behind which gave me a few extra inches to remove the cap and plug the pigtail in.
kayleighk116
Kayleigh
Connecticut
Thanks for the info!
MartyMcFly
I also cut the provided power cord way back as you don’t need as much of the cable as they gave you. The black is negative and the red is the power.
grey
california
Hello I used one of the available 10amp fuse slots. If you go to you tube there is a post on how to do it. I had to file the fuse box to allow the wire to go through so it does not get pinched. The lights comes on when the vehicle is on and turns off when vehicle is off. There is 30secs of the light turning on when your runner engine is off, that’s when your vehicle does its systems check…and it will turn off the raptors lights…this will not drain your batteries.
grey
california
Here is the link to the YouTube video:
Make sure that you use the other spare 10amp in your fuse box along with the provided wire and fuse.
kayleighk116
Kayleigh
Connecticut
Thank you for the video!
