Window rattle
tangobravo
TRD Offroad Premium
Had this same issue on my past 2 Tacomas where the front windows rattle when cracked open. Can't believe toyota has not fixed this! Anyone else notice this and fixed it yet? Its probably the same fix as in the Tacoma.
George
George
El cajon
2025 trd off road
I believe, if I understand the issue, is a problem with most 4 door SUVs
If one back window is open the air pressure causes a throbbing. My solution is to crack the rear window. My 2007 4runner did it. My 2025 4runner does it. Other vehicles I have ridden in did it.
tangobravo
tangobravo
TRD Offroad Premium
I had that on my previous tacomas, but thats not the issue. If the front window(s) are cracked and you go over a small bump or pothole or something the window shakes back and forth and rattles. On my tacomas i had to take the trim piece off and put a little foam or something in there to put some more pressure on the window and that solved the problem. I took the same piece off on the 4runner the other day and it seems to be built different so I can't do the same fix as i did in the tacoma
