Will this tire size fit with OME lift?
WorldAblaze
Shawn
Alabama
2026 Heritage Blue 4Runner ORP i-FORCE MAX
I am currently waiting till OME releases their heavier spring/tuned MT64 set, but I'm trying to figure out what tire size will fit with it.
I currently have the 18inch 2026 Tundra TRD Pro wheels and tires (285/65 r18 or 32.6x11.2 r18) on my 4R (not sure of the offset on these) and I don't experience any issues. I am leaning/wanting to go with 285/70 r18 Ko3s (33.7x11.2 r18) I don't think a inch increase in height with the lift will cause issues, but wanted to see if anyone else is running something similar and any opinions.
My main concern is rubbing at full flex and if this tire size would rub against the trd pro 4R mud flaps (the wider ones)
I spoke with ARB and they said they don't technically have a recommended tire size, but usually 33x11.5 is the most common and If i remember correctly that's what ICON recommends with their 2.5 inch lifts.
odins_beer'd
I have OME setup, 3in front and 2.5in in the rear. I have 295/75r/17's (34.4x11.6R17) in +25 offset. All I had to do to prevent slight rubbing was a crash bracket delete which is 3-4 bolts and the bracket slides up and off. Then I went with the ARK crash bracket delete covers to prevent mud and debris from getting into the frame. well worth it
3rdRunner
Bill
I run 35/11.5/17 Toyo R/T Pro (34.8x11.4 actual) + 25 offset rim on my Trailhunter OME with Westcott Preload Collar Kit (+2.5”). The only time I have had any sort of rubbing at all is at mid-lock (tire closest to the front fender) and suspension completely compressed coming off ledge - and that was minor. Other than that they clear, tuck and articulate fine. Your MT64 is capable of 3” of lift up front if you think you need it - though I suspect you’ll be fine with 2.5” of lift and a 285/70/18. Can’t speak to the mud guards
