Westcott Designs Preload Collar Lift Kit on SR5 - transfer factory rubber piece?
Kyle
St. Louis, MO
2026 Toyota 4Runner
Question: On the factory SR5 front struts there is a rubber piece on the lower spring perch, am I transferring the rubber piece to the preload collar?
828findadventure
Tacoma & Tundra
Does this help?
Climbandroll
Va
I installed this myself and wondered the same. In the vids they did not keep it or mention it but I still wondered whether it would even fit. It did not. It conforms/fits to the OEM steel spring perch and has one or two rubber tabs/nubs that seat into a depression or hole in the steel. Those bits prevent the rubber from form fitting to the Westcott collar/perch. Even if your shaved them off the rubber is not shaped in a way that I could see it fitting against the WD collar. I messed with it long enough to be fairly certain.
Climbandroll
Va
To be clear, this regarding the front. For the rear, the rubber (or maybe poly) puck stays and the WD alum puck sits on top of it.
