Ty43mm
Ty43mm
Terrence
LA
4Runner TRD-Off Road Premium
I'm interested in the tailgate ladder, but I have a power lift. Will there be an issue with the power actuators with the extra weight of a ladder?
No issue at all. The ladder is aluminum but its hold very well. So light weight and built like a tank. Climbed on it 100 times and no issue whatsoever. Just take your time when installing to get the measurements right and drilling.
Ty43mm
Ty43mm
Terrence
LA
@Ty43mm , I noticed your in channel window visors. I've been debating about installing one but not sure.
Are they working out well for you? If so, what brand? If it does include visor clips, does it make contact with your windows when rolled up?
Worried these in channel window visors will cause scratches on the windows and also compromise the rubber weather strips.
when you get a chance, let me know. Thank you.
So far after 5,000 miles in with the visor I’ve ran into no issues. The key is the placement on the visor and the clips you mentioned. Make sure to line it up correctly along with the 3m attached. The clips are in a secured spot where it does make contact at the top edge of the window but I have not seen any scratches on after rolling the windows many times. If you install it correctly, there should be no issues. I believe these are from husky.
