Transmission warms up, then cools and takes longer to warm up
RandomSquirrel
Ashburn, VA
'26 ORP Hybrid, '95 BMW 318ti, '93 Ford Mustang, '13 Triumph Rocket III Roadster
So recently I started to notice that for the first 2-4min of driving (it's cold here in NOVA), the trans temp will warm up to about the 3rd "mark" (moving about 25-50mph), and then as soon as I turn to merge onto the highway, it instantly drops down to "full cold", and then takes another 5-10min to start to warm up again and then stays in the normal range. Is this "normal" behavior, or a sign of a possibly underfilled transmission and when I take a "harder" right turn, the fluid shifts and then fills the lines properly?
either that or a bad sensor?
i had a mechanical temp gauge in an old toyota i could tap the MID screen cover to make it flat line and tap again to go back to correct reading.
RandomSquirrel
RandomSquirrel
Ashburn, VA
With only 352 miles on her, I'd hope it's not a bad sensor. Lol But possibly worth a dealer visit if it doesn't rectify itself.
Cranberry
Dan
Manitoba Canada
What your describing is 100% normal.
Heat in transmissions is generated through gear hunting / constant gear changes.
When you hit highway speeds the truck is likely sitting in the same gear while you cruise, thus not generating major heat that can be detected on the sensor. I assure you the transmission is warm and if you touch it, it will likely feel warn, its just not as hot as it would get if city driving or hunting through 4 gears constantly.
This is why “tow” mode downshifts the truck and keeps it in higher gears. To maintain a powerband area but also eliminating constant gear hopping that will generate heat and blow the transmission.
Wahoo
Alabama
2000 Land Cruiser
I have an SR5, which may have a different gauge appearance for the transmission than yours, but I generally drive with the engine oil and trans temp gauge screen showing, at least until it warms up (after which I switch to watching boost). In my experience, per the gauge my transmission temperature increases linearly, and I don't see swings like you describe (and certainly not a noticeable temp increase in the first 2-4 minutes of driving).
My morning commute is neighborhood/city roads for 5-10 minutes to start, and then interstate speeds for 10 minutes. It usually takes all of the first half of the commute for the trans temp gauge to get to halfway, where it generally sits.
Now, if I were really curious as to actual temperatures, I wouldn't rely on the Toyota gauges. I'd use a scanner.
Toyota transmission logic shifts differently when cold too, it will keep in lower gears until warmed up. Tranny ECU does all it can to prevent someone killing it but it can't prevent misuse
However all bets are off if fluid is actually low.
Real answer is to physically check fluid level and then go from there.
if you suspect it is low, then check it using the TIS procedures.
Joe Dirt
Well I will chime in, I am a oil guy and I always keep an eye on oil temperatures as well as water temperatures.
I was watching mine from day one and it was always taking a long time to warm up and still does and I live in socal.. The truck is just barely over 2K now.
I did check the transmission fluid and it was a little low at temperature.
I am going to check front diff, rear diff and transfer case this weekend.
Easy to do and will put peace to my suspicious mind.
Yours does not sound like the way mine operates. So which one is correct?
For sure sounds like a dealership visit for peace of mind. Good luck
Mman611
Michael
Ansonia, CT
2006 Subaru STi, 2019 Lexus IS300 RWD, 1995 BMW M3 (track toy), 2021 KTM Duke 39
I noticed the same condition with my runner, I asked at my first Serivce and was told there is a thermostat in the transmission. Closes when cold and when it starts to warm up, it opens releasing the rest of the cold fluid then all of the fluid comes up to temp
