Markarian421
Earth
2014 FJC TTUE MT
The Ground Clearance on the First Edition and Premium is 8.7". Considering it's being compared to the TRD version of 4runnuer the chart should probably use the 8.7" number.
Agree -- I can't find the 8" number anywhere, just 8.7". Does anyone have a better source for ground clearance vs. trim level for either LC or 4Runner? I'd suspect it's a bit higher on the offroad 4Runner trims than the non-offroad trims.
pavel
home
none
any ideas where to look up non-core specs for both? Smaller things like:
  • sheet metal used for body panels (same thickness? same alloy?)
  • is windows glass double pane for any of two? for all windows?
  • body paint thickness (afaik lexus normally gets thicker layer, what about LC?)
  • combined legroom (it seems that LC's second row gets more leg room, but what's this "more" in numbers?)
  • headroom 1st/2nd row with(out) moonroof
  • cargo area volume (hybrid, non hybrid)
  • mechanical stuff (are same driveshafts are used? same radiators? same front diffs? same steering rack, etc...)
Most reviews online are like "hey, hi, hello! here is your ground clearance and horse power. Look, that's me on the second row. Good bye!" :)
For some demographics (families, dog owners or both) cargo volume will be important aspect in decision making. I guess it is obvious that 4R non-hybrid will have more space than hybrid 4R, but how non-hybrid 4R compares to LC (LC is ~5" taller, how does it affect cargo area)?
Markarian421
Earth
2014 FJC TTUE MT
I've been compiling an expanded version of this comparison table for my own decision purposes. A couple recent points:
In this video a Toyota engineer at a SEMA measuring event says the Lexus GX and LC are designed to fit 33" tires stock and in general to avoid needing body mount chops. Probably applies to the 4Runner as well.
My Next SUV Build? Parked Side-By-Side: New Lexus GX vs Toyota Land Cruiser!
In this video David gets close enough to the tire on the 4Runner Trailhunter to see it has the same 265/70R18 size tire as the Land Cruiser. At this point I'm going to guess that's what all the 4Runners have.
30 THINGS YOU SHOULD KNOW ABOUT 2025 TOYOTA 4RUNNER // PLUS ENGINEER'S QUALITY CHECK
Gastan
Tacoma TRD Pro
  • Fuel Tank Capacity / Gas Tank Capacity: 19 gallons
Glad Toyota decided to give the 6th gen 4Runner larger fuel capacity than the Tacoma (18.2 gal.) and Landcruiser (17.9 gal.)
kzrman
Maine
2025 Trailhunter
Too bad that we don't know what the inside dimensions are, especially the drivers head room.
I'm considering a Trailhunter, and being 6' 2"" it's a concern.
At least it doesn't come with a sunroof which is helpful.
kzrman
Maine
2025 Trailhunter
Here are some figures comparing the 4Runner Trailhunter against the Land Cruiser - land cruiser and the Lexus GX550 Overtrail+.
Personally my vote is for the Trailhunter. I love the fact that it has better rock crawling abilities and that I don't half to spend my money on premium fuel.
Feature2025 4Runner TrailhunterToyota Land CruiserLexus GX550 Overtrail+
EngineI-FORCE MAX 2.4L Turbo Hybrii-FORCE MAX 2.4L Turbo Hybri/Twin-Turbocharged 3.4L V6
Horsepower326 hp326 hp349 hp
Torque465 lb-ft465 lb-ft479 lb-ft
Transmission8-speed Automatic8-speed Automatic10-speed Automatic
DrivetrainPart-time 4x4Full-time 4WDFull-time 4WD
Ground Clearance10.1 in8.7 in9.84 in
Approach Angle33°31°26°
Departure Angle24°22°23°
Breakover Angle24°25°21°
Towing Capacity6,000 lbs6,000 lbs9,063 lbs
Fuel Tank Capacity19 gallons17.9 gallons21 gallons
Recommended Fuel OctaneRegular (87)Premium (91)Premium (91)
Suspension SystemOld Man Emu ShocksTwin tube shocksAdaptive Variable Suspension with E-KDSS
Wheelbase112.2 in112.2 in112.2 in
Overall Length194.9 in196.4 in192.9 in
Overall Width77.8 in77.9 in75.2 in
Overall Height70.8 in75.7 in73.6 in
Safety FeaturesToyota Safety Sense 3.0Toyota Safety Sense 3.0Lexus Safety System +
Infotainment System14" touch screen display12.3" touch screen display14" touch screen display
MSRP Starting Price$68,350$61,470$80,395
2025 2026 4runner 6th gen Specs: 2025 4Runner 6th Gen trims, models, colors, MPG, dimensions, GVWR weight, towing, clearance, approach / departure / breakover angle Compare 2025 Toyota 4Runner Trailhunter-Toyota Land Cruiser-Lexus GX550 Overtrail plus
  • Like
Reactions: MJE
Nostik21
2018 Jeep Wrangler Rubicon JLU
Anyone one know if the angle approach difference is largely due to the air dam?
I’d be curious what these look like with that removed
2025 2026 4runner 6th gen Specs: 2025 4Runner 6th Gen trims, models, colors, MPG, dimensions, GVWR weight, towing, clearance, approach / departure / breakover angle 1748287810835-lk
pho ban
MN
2006 4Runner Limited
When the chart says "driver position memory function", does that always mean 2 driver memory positions? My wife and I have very different heights and body builds.
Salt Air
Bill
Fl
2025 Toyota 4Runner 4x4
Active grille shutters are a new technology for the Toyota 4Runner starting with the new sixth generation, introduced for the 2025 model year. They're designed to improve fuel efficiency and regulate engine temperature by optimizing airflow.
