Rear sag with travel trailer
Jeff
Jeff
FL
Yes. I don't know which one yet
Jeff
Jeff
FL
Yes but I don't know which one yet
personally when i do get into camping with a towed camper, i will be looking for fully loaded campers with a gvwr of 4500 lbs (max) or less, ideally around 4000 lbs. its just the two of us so we dont need anything fancy, just a good bathroom and a decent fresh tank size and black and good off grid power bank.
with the added options i think mine tops out at 5900 towing. keeping it around 4500 or less will keep the ratio around 75% @ 4500 and around 65% @ 4000
have to keep it under the majik number of 80% ratio as a minimum. i'd rather have the safety margin more so than anything.
PNBC4Run
PNBC
Los Angeles
2026 4Runner TRD Sport
My wife and I are planning on taking a 1 year trip around the country in a travel trailer. I have a 2026 trd off road hybrid. I have figured out all the specs except how to deal with the rear axle sag when the trailer is in tow. I looked into both airbags and heavy duty springs. The airbags take away from my off roading ability and the springs give me a stiff ride when not having the trailer hooked up. Does anyone have rear world experience with this.
We have 2026 TRD Sport 4x4 and tow an Airstream GVWR 4,300 lbs, tongue weight 490 lbs. We have the Blue Ox Weight Distribution hitch and Sway Pro bars, and when properly set up, no sag, no bucking on the freeway. Smooth as silk. But without the sway bars engaged, it does sag.
We are also VERY mindful when loading the trailer and 4runner, and anything heavy in the 4runner gets place in front of the rear axle, back seat area.
We also brought the tire pressure on the Airstream down a bit which helps with the "earthquake effect" inside the trailer during driving. The whole rig handles better too. Airstream tires are rated at 80psi, and we consistently run on 60-65psi.
Note that if you have running boards or other extras installed on your 4runner, that will affect your maximum tow capacity.
Gator 22
Florida
2021 TRD Off Road
I'm sure the way you are running it makes it not sway but with the numbers you are showing you need more tongue weight to get to at least 10% which is the minimum to be correct. 11-12% is the sweet spot. Without the sway bars you would probably get sway with the 8.7% tongue load you have. You can load gear in the trailer in front of the trailer axel to add tongue weight. Been through all this many times towing boats with 4Runners. Emergency maneuvers is where you can really get into unrecoverable sway situations even with sway bars.
